Build Threads Details on Club Lexus 1IS owner vehicles
IS300 Aristo VVTI Build
Old 04-26-15, 01:57 PM
antis
antis's Avatar
Default IS300 Aristo VVTI Build
Updates
Oct 15 2015: The car is currently at Induction Performance and will be tuned today.
Aug 24 2015: The car has been towed to Induction Performance to diagnose a triggering issue that is causing the ProEFI to run extremely rich and to get tuned. The car should be done by the end of this week.
Nov 19 2014
I made the decision to purchase a 2JZGTE VVTI from an Aristo. I chose to purchase the engine before getting an IS300 because I know that If I had a car to drop this engine into I would want to rush and put the engine in. The original idea was to just do a full maintenance and rebuild/upgrade the R154. Plans have changed and I keep adding stuff to the never ending list. From this point on I will be updating the thread as things get done. I'm expecting to receive a big piece of the build hopefully by the end of the week, really excited about it. I'll be turing on the engine next week to ensure that there are no leaks and an excuse to hear the cams. I will be posting a video.
Feeling like I just adopted my first child.
That same night I just couldn't wait to start working on the 2J.
Nov 20, 2014
I was up bright and early to see my work and continue.
Goodbye twins.
Nov 21, 2014
I got this bad boy on the stand.
Getting the parts organized.
Nov 22, 2014
Painted the valve covers wrinkle black and baking them to cure the paint.
Nov 23, 2014
The head was cleaned and the block was painted glossy black.
Nov 24, 2014
Intake runners painted glossy black as well.
Nov 28, 2014
its looking good.
Dec 8, 2014
Dec 12, 2014
Santa came early. The original idea was to do a complete maintenance on the engine and slap a turbo on it and go. Well the build did a 360. I took a quick drive to Real Street performance and picked up a set of BC 272 cams, BC valve springs, BC titanium retainers, BC keepers and supertech valve seals.
BC 272
Dec 15, 2014
New oil pump
Dec 16, 2014
Followed the TSRM to remove the old cams.
The Toyo Tool tool made it really easy to remove the old retainers
Dec 17, 2014
Somehow I was able to get this great deal from Induction Performance it was a black Friday special in December. I purchased a billet steel timing tensioner and received the Gates Racing belt free.
Dec 20, 2014
I stuffed about 10 feet of vacuum house into the cylinder and turned the crank to compress it, allowing the valve to stay put. The moment of truth came when the retainer was removed. Don't mind the oil sludge.
Old 04-26-15, 02:00 PM
antis
antis's Avatar
Helping out my cousin drop his 2JZ on a MK3.
Thats more like it.
Very time consuming to install the cams.
TOMEI cam gear
Dec 21, 2014
New oil pump ready to be installed.
Dec 21, 2014
New front main seal.
I got really lucky as all the clearances are in spec.
Took a drive down to Miami and got this R154 that will get the all Marlin crawler race upgrades
The order from Curt came in.
Dec 24, 2014
I had rebuilt the vvti cam gear but I ended up putting too much torque and broke the bolt.
Dec 25, 2014
Spent Christmas with the in-laws and they had just upgraded to these two.
2015 GS350 F-Sport
2015 RX350
Dec 27, 2014
Well a few days later we heard to Lexus of Pembroke Pines and we feel in love with the 2015 IS250 F-sport.
Jan 2, 2015
I got sidetracked after the visit at the in-laws and we ended up getting the IS250.
Jan 6, 2015
The reason why I started my build, my cousin's 2JZ. We fired it up that day everything turned out well.
Jan 8, 2015
The IS250 home at last.
Feb 26, 2015
My build had come to a slight pause, we had gone to two cruises and then I came back to work on the build.
Mar 10, 2015
On March 10 for some reason I googled my address and in google maps there I was building the engine stand back in Nov.
April 9, 2015
I went to Titan Motorsports to get a Precision Turbo 46mm wastegate.
Old 04-26-15, 03:07 PM
antis
antis's Avatar
I received this junk from suprastore they offered a replacement but I just didn't like the quality for the price. I returned it.
April 15, 2015
BW S362 FMW
April 18, 2015
My cousin wanted to confirm that the LSD on the MK3 was working. CONFIRMED!
Old 04-26-15, 03:20 PM
antis
antis's Avatar
I'm confused about where the black looking spacer goes. It's made out of hard plastic. It was in the order that I had placed with Curt. I do know the silver washer is for the oil cooler bolt.
Old 04-26-15, 03:31 PM
antis
antis's Avatar
I'm getting the engine ready to test start it and make sure there are no leaks. Can't wait to hear those cams.
April 21, 2015
Painted the water neck wrinkle black.
I also painted the pulley with high heat low gloss black.
April 23, 2015
I ended up getting a cast manifold from eBay. I had to use these nuts on those two studs as the stock nuts would not fit.
B]April 26, 2015[/B]
The porting was suppose to be done by a good friend, but I grabbed the dremel and did it myself. I also polished it.
Old 04-27-15, 04:46 PM
statusdrew
statusdrew's Avatar
Yes!! I live in the Pembroke Pines/Miramar area, we should link up!! I have an 05 IS me and my boys are getting ready to do this same swap on. We aren't sure if we are gonna run stock twins or single, I don't want any more than 400-450 whp (It's my daily and my wife will be driving it occasionally as well.)
Hope we can chat bro, would love some info on your process so far!
Old 04-27-15, 05:37 PM
antis
antis's Avatar
I'd go single for that range you will love it. You can spend a good $550 on a decent BW turbo and be good. I actually visit the in-laws on the weekend that live in Pembroke Pines.
Old 04-27-15, 06:12 PM
statusdrew
statusdrew's Avatar
Thank you for the suggested boss! I will be doing the swap once I finish with the chassis and brakes (Already finished my suspension with coils, sway bars and adjustable arms F&R)
I'll keep you updated with everything when I start, I'm sure I'll have many questions. Even help physically with some things like porting and stuff, don't worry, I'll pay for anything you help with.
Old 04-27-15, 06:27 PM
antis
antis's Avatar
For sure just PM me anytime when you are ready or have any questions.
Old 04-29-15, 10:06 PM
antis
antis's Avatar
Today I received the order from DriftMotion, which included drain flange for turbo and oil sump, turbo oil feed line, new bolts for the valve covers, oil outlet adapter fitting and o-ring kit for the injectors. This is everything I needed to fire it up but DriftMotion didn't include the gasket for the turbo drain flange. The stock injectors were temporary installed as the plan has changed. I made my own turbo drain and feed kit. Most of the vacuum lines have been installed. The aristo harness has also been temporary installed as I will be using a GE harness. The engine has been filled with fully synthetic oil.
Second oil feed that used to go to one of the turbos has been plugged with a oil pan drain plug. (seen on the bottom left on the block.)
Old 04-30-15, 12:38 PM
antis
antis's Avatar
I installed spark plugs, wires and coils.
Old 05-02-15, 04:38 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I love how meticulous your being about building the complete motor and how it looks. Nice job
Old 05-05-15, 05:18 PM
VMRWheels
Former Sponsor
VMRWheels's Avatar
+1
Can't wait to see the end product
Old 05-06-15, 02:56 PM
antis
antis's Avatar
I got a good deal on this small package. It includes the PNP harness for 02-05 IS300, 5 bar map sensor, IAT sensor and a few extra pins. I'll be adding more sensors that I know I can get for better prices, like the flex fuel sensor, Honeywell 150 psi fuel, oil pressure sensors and coolant temp sensor. This was a big decision, I wanted the PROEFI 128 features on my build and here it is. After two weeks of waiting it's finally here.
Old 05-07-15, 08:09 PM
antis
antis's Avatar
My painting booth.
I stay baking.
The finish product.
Quick Reply: IS300 Aristo VVTI Build
