Unique FSport DUAL IS250/IS350 build[s]
That looks good. I love how it looks on your car. I hate dealing with replica kits. My diffuser don't even fit at all. Not sure what I want to do with it since I got it painted already. Some guy told me he had to use a heatgun and basically melt the polyurethane into shape.
How much did it cost you to mold the diffuser?
I did this long time ago and forgot how much I paid but talk to Long in DTM Autobody, let him know Kevin with two Lexus IS refer you here, he will take care of you.
Thanks man. For big and complex flow like that, it is best to mold it. It cost a bit higher but worth it. Even authentic parts installed doesn't look as good as molded replica because without molding, you will see the seam lines no matter what. I had the same diffuser installed on IS350 (not molded), it fits well but there are gap in the line which doesn't look as good.
Is that body shop in Socal?
I'm not even sure my diffuser could even be molded at this point. The fitment is super off. Like it is a joke. I'll try to get a pic of the fitment of my diffuser. The middle part looks fine, it's just the left and right part that goes to the side of bumper that doesn't fit.
Good luck with your project.
When I received my part, it seems off too especially the left and right side like you mentioned but DTM bodyshop was able to make it fit probably with some bending and heating that I'm not quite sure. Yes, they are located in El Monte. http://dtmautobody.com/ to see their sample work.
Thanks for your help.
What dampening stiffness difference in ratio do you recommend between the front and rear shocks/coilovers?
How much wheel gap does the front and rear have on the IS250? How's the ride comfort compared to stock?
Is the tire to fender gap the same all around on your two vehicles or is the front slightly higher/have a bigger wheel gap?
For street comfortable driving, I find that 18 clicks (away from stiffest) and 22 clicks (away from stiffest) is the sweet spot. I find having a bit softer rear give some more comfort. The front cannot be too soft or else you will be bottoming or rubbing all over.This really depends on your personal preference.
In general, the softer the shocks, the better it absorbs bump but more body lean while stiffer settings will give you firmer and sharper handling with reduced body lean. Stiffer settings don't absorb bump quick enough so it is jarring to the ride quality. Also, too stiff on the rear can also be a bad thing because you end up spinning the tire easier.
Therefore depending on the road condition, for better handling, you need to adjust accordingly. On race track where it is perfect flat road without pot hole, you can go as stiff as you can for sharper handling feedback. However on street with bumps and imperfections, you should use softer settings to be able to absorb the bumps, else it is jarring ride and also you will spin the tires here and there especially in wet condition which can be dangerous.
I don't slam my car but I lower it enough for better handling on street and the sweet spot for me is about 1 finger gap front and 0.5 finger gap rear. I believe this is about (1.7 inch front and 2 inch back). The ride quality depends on the dampening settings, with the 18/22 (away from stiffest), I find the quality very close to stock. It has better ride quality than my lower springs set up that I tried before.
I like to have a little bit more gap in the front to have more suspension travel to absorb bumps and avoid rubbing/scraping/damaging front bumper lip issue. I can drive in any driveway, gas station, parking lots etc without much problem.
DWS
Pros: Will last a long time (expecting 40-50k miles?), very comfortable, very quiet, good handle for street on dry.
Cons: Weak fat and ugly sidewall, does not handle well in autocross/track, not too good in rain (I spin my tires various times in rain lol).
Hankook V12:
Pros: Handle awesome both dry and wet, handle quite good in autocross/track, half price of Michelin Pilot Super Sport but handle just as good as PSS, easy to drift with (I did that legally on autocross), quiet, good looking sidewall.
Cons: Lasts a lot shorter than DWS (expecting 20-30k miles?).
If you want to save money and comfortable tire that handles so so, go with DWS. If you want performance, go with Hankook v12.
I went with Bridgestone Potenza S-04 Pole Positions, hope they do me good.
Do you have any FIGS engineering parts or bushings installed?
I have Continental DWS ultra high all season tires on IS250 and Hankook V12 high performance summer tires on IS350.
DWS
Hankook V12:
DWS
Hankook V12:
No, I don't have FIGS #2 poly bushings. I might get it in the future but I don't have inner tire wear for now. I find it helpful to run exact 0 toes on all 4 corners when you do alignment, it helps prevent inner tire wear.
