Build Threads Details on Club Lexus SC owner vehicles
New to the forum with some questions
Old 10-07-14, 06:22 PM
Sc2jzc
Sc2jzc's Avatar
Default New to the forum with some questions
My name is cory I'm from Ohio and I recently picked up a sc with a 2jz swap with a percision 62/62 turbo and couple of other goodies. Some issues I'm have n
1. Drive shaft slaps at low speeds only
2. A high pitch noise is coming from driver side back of motor by firewall
I know info is vague but any help would be great
Old 10-22-14, 02:40 PM
Ali SC3
Ali SC3's Avatar
Not sure about the driveshaft, will have to go under there and take a look and see if anything looks out of place or loose. the bushings could be worn or lots of other things on a swapped car, so hard to say.
The second one sounds like the idle air valve. it sort of makes a sounds sometimes when its sucking in air especially if someone removed the factory hose and stuck a filter on the end of it (JDM swaps with map sensor can do this). usually nothing to worry about unless its leaking, or you have another air leak back there or something.
suprasoup
Performance & Maintenance
11-13-18 09:04 AM
omee
12-11-17 12:33 PM
BoostedE21
02-15-10 12:13 PM
breakb
SC- 1st Gen (1992-2000)
02-11-08 10:32 AM
Quick Reply: New to the forum with some questions
