Build Threads Details on Club Lexus 2GS owner vehicles
Luxurious but Not VIP
Old 09-03-14, 09:23 AM
whiteraven
whiteraven's Avatar
Default Luxurious but Not VIP
figured i'd start a build thread.
Here are a couple toyotas i've owned in the past.
87 Corolla GTS
is300
86 Cressida with 1jz
Another Cressida also had 1jz and 1uz before that.
Currently own these guys:
Cressida
Old 09-03-14, 09:39 AM
whiteraven
whiteraven's Avatar
Here the GS when I first bought it.
Coils came in!
They are alot shorter than stock. haha
how low can you go? threw a set of cosmis racing s5r 17x9 +22, rear needs spacers.
More reasonable daily height.
Old 09-03-14, 09:50 AM
whiteraven
whiteraven's Avatar
Fresh oil change.
I had a r154 left over from another project and decided to convert the GS to 5spd.
In the process of removing the lower dash to add a pedal, I found a button.
Turns out it's for a radar detector! haha awesome.
Xcessive Manufacturing SC300 Clutch pedal that i'm making fit.
Fuse box has to be moved. not enough room for a master.
much better! need to clean it up.
Old 09-03-14, 10:21 AM
monkey92
monkey92's Avatar
another conversion interesting
Old 09-03-14, 11:18 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
cool build....
Old 09-03-14, 11:37 AM
angus
angus's Avatar
Waiting to see the outcome, I will most likely do one of my GS4's to manual as well.
Old 09-04-14, 05:33 AM
sicksearch
sicksearch's Avatar
very nice look man
Old 09-04-14, 01:15 PM
SC4Paulo
SC4Paulo's Avatar
welp, it seems that much more easier to go 5 speed on a 300 vs a 400, itll be around 2k for a 5 speed swap in a 400 :/
Old 09-04-14, 01:34 PM
1sWt2GS
1sWt2GS's Avatar
loving that 5 speed swap
Old 09-06-14, 12:31 PM
SuperiorSC
SuperiorSC's Avatar
Can't wait to convert my car. Very nice keep us posted
Old 09-08-14, 11:49 PM
xdavid408x
xdavid408x's Avatar
not hating man idk if im too lit haha 17s look kinda small tho haha
Old 09-09-14, 04:57 AM
SZA
SZA's Avatar
I actually like the wheel/suspension setup. With those coilovers you can go super low on the 17s. Gives the car an aggressive look that you just don't see on other 2GS's. Kudos.
Please post detailed pictures of your 5 speed conversion. I think it would really help out the 2GS community a lot. There's a lot of explanations of how to convert it but pictures are lacking.
Is there anything different about the SC300 clutch pedal assembly from Xcessive Manufacturing? It looks like the bracket is custom? I am curious as to how this will work out as far as pedal placement. The other swaps I have seen have the pedal way to the left or too close to the big bulky automatic brake pedal.
I have been thinking of using a clutch pedal set from Wilwood along with their Clutch Master Cylinder. It's small and would probably be easy to mount.
http://www.ebay.com/itm/like/231147388154?lpid=82
Keep us posted and good luck with the rest of the build!
Old 09-09-14, 07:50 PM
sugzz
sugzz's Avatar
Looking forward to the outcome. Good luck with the build.
Old 11-05-14, 02:40 PM
whiteraven
whiteraven's Avatar
Thanks guys.
I got some more parts in.
Spec clutch
my flywheel has been resurfaced.
Another glamour shot. lol
Some stuff i've found for the 5spd conversion:
stock trans xmember will work without being drilled out if you use a jzx90 or jzx100 trans bushing.
XM's SC pedal placement is way off from where it needs to be, I am working with him on getting a good fitting pedal for the GS.
Old 12-18-14, 01:58 AM
angus
angus's Avatar
Originally Posted by whiteraven
Thanks guys.
Spec clutch
Any more pics of the car with those wheels? I am looking at going 17x9
And please do update us on the clutch pedal as I am getting closer to doing the 5spd in my GS4
Quick Reply: Luxurious but Not VIP
