hcharlesc3 GS300 Build
#46
Your alignment is fine. You're not getting to those stock camber ranges unless you buy a camber correction kit or raise it back up to stock height. New wheels aren't going to change that. I'm confused by your wheels and camber settings though. I'm running -2.7 in the rear with a 19x11+24 and my wheels hit the very bottom of my fenders (they're almost shaved flat). Have you compressed the suspension yet to see if the lip clears the fender? You don't want to find that out hitting big dip at 65 mph.
#47
#48
I'm running 255/35 nankang ns-20's. Hopefully, you find time to fit the bracket. I am very interested to know how that works out. I currently don't have an area of my own to work on my car so I haven't been able to look into it, but I really would like to start stacking parts if I know it will work.
It's a pain when my cars on the interstate because hitting dips at 60 mph results in my fender and lip kissing.
#51
ISF/Vette BBK
First let me say it is very well made and comes with all of the hardware needed to install everything. I did get a chance to see how well it fit. First i lined it up with the caliper bracket and the bolts line up perfectly. When i tried to mount it the cut out for the hub on the bracket was too small so i'm guessing the circumference of the hub on a gs is bigger. It looks like if you take off about a half inch off the bracket facing the hub it will fit perfectly. It definitely looks like it will clear the tie rod end and the rest of the suspension. Hopefully this weekend i can mock up a bracket from cardboard and see if i can cut it to make it fit. If anyone has any input on how I can get these to fit feel free to chime in. Here are some pics.
Also if anyone has a tte lip real or rep please shoot me a pm
#57
Tried out the vette caliper bracket and only the bottom hole lines up. The top hole hits against the the arm going to the upper ball joint.
I'm going to try and mock up a cardboard bracket to see if I can't get a bracket made. Does anybody know if the position /angle of the caliper changes anything? I know some vehicles have the calipers towards the front of the car and some towards the rear?
#58
You have the bracket the wrong way. The bracket goes the other way. You can tell because the big cutout is to go around the spindle on the sc. The ears are for the calipers. You can see the ears pointed out on the picture of the sc I posted above. After you turn it the other way, you're probably are going to have to trim the side facing the spindle. Those triangles will probably have to come off and that side will be flat similar to the bracket above. I think the bracket can work, it just needs trimming.
