Build Threads Details on Club Lexus 1GS owner vehicles
My New 1993 GS300 Project
Old 04-27-14, 01:30 PM
Luxor
Luxor's Avatar
Post My New 1993 GS300 Project
Hello CL. I purchased this 1993 GS300 from a lady about a month ago for $800. Has 160,000 miles on it. I purchased it as an investment and as a daily driver while my SC300 gets a turbo installed. I bought it with a leaking water pump and a horrible vibration due to the radiator fan not being mounted correctly. The GS actually overheated on me on the drive home right after I bought it.
The person who installed the water pump installed the wrong water pump (it was meant for 2nd Gen GS) Our radiator fans will not bolt onto 2nd Gen GS water pumps due to the shaft being too big in diameter on the water pumps. So the previous stupid mechanic installed the fan using WASHERS as spacers. The nuts were not tightened enough resulting in the fan being wobbly. On top of that, the water pump itself was not installed properly because all the water pump bolts were hang tightened. One of the bolts backed off and fell into the timing belt cover which chewed the crap out of the timing belt. I am shocked that the timing belt didn’t break on me.
I have already installed a new water pump and a new timing belt so she runs great now. Here is a list of the good and bad about this GS300.
Good:
  • Clean title, never been in an accident
  • Bought it with new tires
  • Cold AC, hot heater
  • Has a new radiator and thermostat
  • Has new lower control arms
  • Has new inner tie rods
  • Has new outer tie rods
  • No dents
  • No rust
  • Came with receipts and owners manual
  • Nakamichi radio and working CD changer
Bad:
  • Leaking valve cover gaskets (fixed)
  • Old peeling tint
  • Paint peeling on front and rear bumpers
  • Badly stained carpet (fixed)
  • Leather has rips and aged really bad
  • Center console wood missing (fixed)
  • Steering wheel worn badly on top (fixed)
  • Front passenger window regulator bad and will not roll down (fixed)
  • Rear driver window not getting power (short in the wire inside door) (fixed)
  • All window switches wood veneer peeling/missing
  • Driver door window trim pulled out (common problem on GS)
  • Yellow headlights
  • Sunroof will not slide back and misaligned
  • Passenger seat off track (fixed)
  • Driver seat makes grinding noises when sliding (fixed)
  • Worn shift ****
  • Missing cup holder (fixed)
  • Only has 1 master key and the button is broken
  • Antenna will not go up
  • Radio has a black thing in front of screen
  • Bleeding climate control
  • Tachometer sticks
  • Mis-matched wheels LOL
I will update this thread with more pics and with all the fixes and improvements that I will do to this GS. I am going to keep the car stock. I just want to restore this GS and make it look nice and functional.
Attached Thumbnails My New 1993 GS300 Project-gs300-first-pic-driver-side.jpg   My New 1993 GS300 Project-gs300-first-pic-pass-side-.jpg
Old 04-27-14, 01:51 PM
TRACKMKIII
TRACKMKIII's Avatar
Wow that's quit a list of bad things but several of those things are pretty common and can be fixed fairly easily. The car looks pretty good and for $800 you can't loose. Post some pics of your SC.
Old 04-27-14, 04:55 PM
Luxor
Luxor's Avatar
Yea, I plan on getting most of the problems fixed but I will focus on getting the valve covers fixed and car re-tinted first. Here is a picture of the SC.
Old 04-27-14, 05:05 PM
Luxor
Luxor's Avatar
Thumbs down
Here is how the water pump hack job looked like when I bought it. I don't know how this fan stayed on the pulley. Those nuts were barely on there.
When I took off the timing belt cover, I crapped myself. I've never seen a timing belt look like this before. This was a result of a water pump bolt backing out and falling inside the timing belt cover and chewing the timing belt and bouncing around in there. Somehow the timing belt didn't skip any teeth from this.
Attached Thumbnails My New 1993 GS300 Project-gs300-water-pump.jpg   My New 1993 GS300 Project-gs300-timing-belt.jpg
Old 04-27-14, 07:12 PM
joewitafro
joewitafro's Avatar
Hope you decide on building this GS like your SC! Sick pickup! great project car
Old 04-27-14, 07:26 PM
TheMole
TheMole's Avatar
SC looks very clean and nice pickup on the 1GS! Ball joints looking ok in the front?
Old 04-27-14, 07:42 PM
TRACKMKIII
TRACKMKIII's Avatar
Thats the second time I have seen the wrong water pump on these cars.
Old 04-27-14, 09:14 PM
Luxor
Luxor's Avatar
I am not trying to put too much money into this car since my SC is a money pit.
Thanks! The GS has new lower control arms so I assume the ball joints are good. Do 1st gen GS have ball joint problems?
The water pumps looks 100% identical and bolt up, the only difference I noticed was the shaft diameter.
Old 04-28-14, 08:38 PM
TheMole
TheMole's Avatar
^Yea there have been some cases similar to how the 2GS balljoints fail. Good news is that the balljoints can be replaced independently unlike the 1SC. Might be worth checking out the next time you're under the car.
Old 04-29-14, 07:54 PM
Luxor
Luxor's Avatar
Here are some pics on how the GS looks like currently.
Attached Thumbnails My New 1993 GS300 Project-gs300-back-side1.jpg   My New 1993 GS300 Project-gs300-back.jpg   My New 1993 GS300 Project-gs300-back2.jpg   My New 1993 GS300 Project-gs300-side.jpg   My New 1993 GS300 Project-gs300-console.jpg
Old 04-29-14, 09:52 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Definitely not bad for 800 bucks!
Old 05-04-14, 05:20 PM
Luxor
Luxor's Avatar
Default Front passenger window regulator
Took the door panel, window and regulator off today to see why the passenger front window will roll down but not roll back up. Turns out the regulator is toast, the green plastic clip by the wheel is broken and the cable came off the wheel and the plastic part where the cable goes through the motor housing has also broken off. Time to hit the junk yard and find a used regulator.
Attached Thumbnails My New 1993 GS300 Project-gs300-pass-regulator.jpg   My New 1993 GS300 Project-gs300-pass-regulator2.jpg   My New 1993 GS300 Project-gs300-pass-regulator3.jpg   My New 1993 GS300 Project-gs300-pass-regulator4.jpg
Old 05-14-14, 05:39 PM
Luxor
Luxor's Avatar
Had a busy week. I ordered a bunch of OEM parts for the engine. I replaced both valve cover gaskets, intake manifold gasket, distributor, rotor, spark plugs, and distributor oil seal and PCV valve.
Attached Thumbnails My New 1993 GS300 Project-gs300-engine1.jpg   My New 1993 GS300 Project-gs300-dist.jpg   My New 1993 GS300 Project-gs300-rotor1.jpg   My New 1993 GS300 Project-gs300-spark-plugs1.jpg
Old 06-03-14, 07:01 PM
Luxor
Luxor's Avatar
Default Replaced Steering Wheel
I did not like how worn and sticky the old steering wheel was, so I found a 1998 ES300 black steering wheel as a replacement. I think the airbag looks better on the ES300 wheel and the "L" emblem is bigger too. It was all plug and play.
Attached Thumbnails My New 1993 GS300 Project-gs300-old-wheel.jpg   My New 1993 GS300 Project-gs300-new-wheel.jpg   My New 1993 GS300 Project-gs300-old-wheel2.jpg   My New 1993 GS300 Project-gs300-new-wheel2.jpg
Old 06-03-14, 07:23 PM
TRACKMKIII
TRACKMKIII's Avatar
Looks good man!! My steering wheel is in terrible like you old one was, I just pick up a black 2GS wheel.
Quick Reply: My New 1993 GS300 Project
