Build Threads Details on Club Lexus 2GS owner vehicles
GS400 2JZGTE Build in the Mitten State
Old 07-18-14, 08:22 AM
  #91
armanitran
armanitran's Avatar
Your car looks great, how's the progress so far?
Old 07-18-14, 08:46 PM
  #92
vto
vto's Avatar
Pretty sick bro, I've followed your stuff on xceedspeed and this is really on it's way, keep up the awesome work man
Old 07-25-14, 12:19 PM
  #93
solaradude
solaradude's Avatar
Originally Posted by Jomeezy
Sick *** builds!!! Keep up the good work man!!
Thank you, appreciate it!
Originally Posted by sinistervr
there are 2 companies that make a solid mount that i know of...
Thanks for the info. I was really after the Cusco mounts for the Japanese bling factor more than anything, lol. I'm sure the Megan mounts will hold up OK and be a lot less harsh.
Thanks! Things always seem to be moving at a snail's pace with two little ones at home, but I am trying to get some wrench time in when I am able to.
Thanks a lot!
__________________________________________________________________________
It's been a long time since I last posted- here's an update on where things stand.
I found after putting my transmission back together that I couldn’t get it to go into gear. I had never torn into a transmission before aside from replacing seals and whatnot, so I called my cousin Nick up for some assistance. Nick is a mechanical engineer for Aisin, the company that just so happened to design and build the R154 transmission.
We were able to take the trans completely apart and verify that everything appears to be in good working condition. I probably could have beefed things up a bit more with some more accessories from Drift Motion and Marlin Crawler while we were in there, but my setup probably won’t see a ton of abuse anyway.
With everything properly reassembled, I installed my Marlin Crawler shifter base bushing, Freed extended shifter housing, and 1JZ bellhousing. The transmission is now finished and ready to be installed in the car, which is a great feeling. Couldn’t be more grateful to my cousin for his help with this.
Next up was the installation of the replacement OEM Toyota water pump. I nearly missed the o-ring located on the block, but after seeing the condition of the seal that was in there I am really glad I caught it.
With the o-ring replaced and the new water pump bolted on, I decided to reinstall my camshafts and replacement cam seals. These are a common oil leak culprit on this engine, and I could tell that the seals on my engine were beginning to fail when I first tore into it.
I was really hoping to install a set of Tomei Poncams while the engine was torn down, but I just couldn’t justify the cost right now. There are a lot of other things I could use the money towards to get this car into a semi-completed state, so those items needed to take priority. Definitely something I would love to install someday down the road though. Here’s a shot of the water pump and camshafts installed. Note that the new timing idler assembly is also now in place:
You can also see that I installed my GReddy oil filter sandwich plate and a new OEM oil filter, as well as the sensors for my Defi oil pressure and oil temperature gauges:
Next came the cam gears. Again, something I would love to upgrade down the road (at least the exhaust side anyway):
With everything set in the valve train, the next step was to install the valve covers with a pair of fresh gaskets:
I tossed a new PCV valve in while I was at it for good measure. My oil cap is cracked, so I’ll need to replace that with a much cooler piece in the near future:
Next it was time to put the timing belt in place:
It was at this point that I realized my lower timing cover was looking a bit worse for the wear. It was caked in old oil and had a few broken tabs, so I decided it would be a good idea to replace it:
The last piece to the timing assembly puzzle was a new timing belt tensioner:
So at this point I am feeling pretty good- the majority of the engine is put together and I can move on to installing the intake and exhaust manifolds, right? Well, when I went to give the engine a couple of quick rotations by hand to ensure everything looked good, I hit hard resistance at just under one rotation. Total bummer… I checked the alignment of the VVTi cam gear and found that I did not have it rotated all the way to the right, but that didn’t solve my problem. If I get the time this weekend, I need to remove the camshafts and try putting everything together again. All of the timing marks are aligned, but I had to have made a mistake somewhere along the line. I suppose that’s all just a part of the build process, but it can definitely be frustrating.
As for new parts arriving, things have been pretty quiet this month. I did however decide on a turbocharger after finding a great deal on one of the forums I frequent. I decided to keep things fairly old school and go with a GReddy T-78 journal bearing tubo. The unit I found was installed on an RB26 but the engine build was never completed, so it is essentially brand new.
I’ll probably get a lot of flack in the 2JZ community for choosing to go with this turbo as there is a lot of newer and improved technology on the market today. But as I am sure most of you know by now, I really enjoy staying true to genuine Japanese components whenever possible with my builds. This setup is sure to be reliable, and will look and sound awesome in the process. While it may be contradictory to the approach a lot of people take, it’s the way I prefer to go.
I also managed to source a second hand GReddy Type R wastegate to use with the setup. These are typically more than $1k new, so I was more than happy to find one in decent shape that has seen a bit of use over the years. The dump pipe was included and I don’t think it is a GReddy piece, so I am not sure if I’ll be utilizing it or not. This is my first externally gated setup, so I’ll have to make that decision when it comes time to fab the downpipe and exhaust.
The next order of business will be to source an exhaust manifold and complete the water and oil lines for the new turbo setup. My hope is to find a TRUST manifold originally designed as a part of the T-78 kit, and I believe I might have a solid lead on one of those. We’ll see what happens though.
Finally, I got bored and decided to toss the hood on the car while it continues to wait patiently for the new drivetrain. I can’t wait to see some crystal clear headlights, a new bumper, and my GReddy intercooler looking back at me from the garage. Here’s a blurry photo that I’m going to post anyway:
I’ll try to do better at keeping everyone updated through the rest of the summer. In the mean time, keep an eye on www.Speed.Academy for updates on my build. Speed Academy is the new venture headed up by my friends David Pratte and Peter Tarach, the guys that ran Modified Magazine before it was shut down earlier this year. I’ll be posting updates on the build over at their site roughly every two weeks in addition to here on my personal blog. I’ll go into a bit more technical detail over there as well, so if you’re looking to rebuild your 2JZ or swap your Lexus GS it should be worth checking out!
Old 07-25-14, 12:25 PM
  #94
armanitran
armanitran's Avatar
great progress! I'm not sure if I asked this already, but are you rerouting the AC or completely deleting it?
Old 07-26-14, 03:57 PM
  #95
Sffd103
Fire Slayer
Sffd103's Avatar
I must say I read your entire thread patiently. Everything you're doing looks awesome so far and it looks very technical and correct. Just the way I'd have it done. The best part is you're doing all this yourself. Nice job!
Old 07-26-14, 11:57 PM
  #96
Chankeye
Chankeye's Avatar
followed your 240 build on zilvia and was sad to see you part it, but i understand why you did it. Now that you have a GS i'm really keen on seeing how this project of yours comes out, with the quality parts you buy and your attention to detail this should be a really good one.
Old 07-29-14, 11:38 AM
  #97
solaradude
solaradude's Avatar
My original plan was to retain it until I learned from helpful folks here on the forums that the GS400 lines do not bolt up to the 2JZGTE. So knowing that I will need to find a place to make custom lines for me, I've kind of set that on the back burner for now. I'd love to have AC on the car when all is said and done though.
Appreciate the kind words! It's easy to get discouraged from time to time with an undertaking like this, so it's motivating to hear stuff like this.
I realllllly miss that car. I honestly wish I would have kept it, but I am sure I would have gotten bored by now if I did. I didn't think I'd be able to have a project like that with a little one at home, but somehow I have two now and I'm still trying to hang. We'll see if I actually follow through, but I hope I do! haha.
Minor update- I found that a couple teeth were broken off of my timing gear, so that slowed my progress this weekend. The new gear should be here from Curt at Elmhurst today, so I'm hoping to toss that on and sort out my timing issue tonight or tomorrow night if things go my way for once.
Old 07-29-14, 11:40 AM
  #98
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
i was hoping for an update lol.. like maybe the engine in the car....
Old 07-29-14, 11:53 AM
  #99
hcharlesc3
hcharlesc3's Avatar
X2
Old 07-29-14, 09:27 PM
  #100
jwin
jwin's Avatar
Don't make custom a/c lines. It's cheaper to swap the Ac from a gs300
Old 08-15-14, 05:12 AM
  #101
tman6925
tman6925's Avatar
This is such an awesome build! Keep up the great work! I'm debating on if I want to swap for the 2jz or stick with the v8. I'm excited to see how this turns out for you.
Old 08-15-14, 07:45 AM
  #102
armanitran
armanitran's Avatar
Is this possible? I should have done this instead of selling my 2JZ and just replacing my V8
Old 08-15-14, 05:05 PM
  #103
Need4Speed
Former Sponsor
Need4Speed's Avatar
Great build, love your progress. Nothing better than wrenching on your own car. Can't wait to hear this beast boost!
All of your past cars were gorgeous.. this will be another
Old 08-15-14, 06:58 PM
  #104
ELLeon
ELLeon's Avatar
This is a great build, it shows a good point to rebuild if you can. solaradude has found several things that if not replaced could have F-ed his engine.
Old 08-27-14, 12:42 PM
  #105
solaradude
solaradude's Avatar
Oh don't I wish that were the case! haha. All of the details are taking way too long with my busy schedule.
Good call, that's probably what I will try to do!
Thanks! The V8 is pretty cool too. I've always wanted to own a JZ powered car though!
Thanks a lot, really appreciate it! I'm hoping so, haha.
Definitely tedious and frustrating for months on end, but I am hoping all of the money and hard work is going to pay off!
Quick Reply: GS400 2JZGTE Build in the Mitten State
