Build Threads Details on Club Lexus SC owner vehicles
w58 to 1uz sc400 swap about ready
Old 04-29-14, 10:01 AM
  #46
kolessc400
kolessc400's Avatar
I will be posting a video tonight of driveing the car
Old 05-07-14, 08:31 PM
  #47
kolessc400
kolessc400's Avatar
Ok so I have been trying to post these videos but they wont post so tomorrow ill get it on here sorry guys
Old 05-07-14, 10:00 PM
  #48
oldManTan
oldManTan's Avatar
no problem, can't wait to see it!
Old 05-15-14, 11:30 PM
  #49
kolessc400
kolessc400's Avatar
Ive been trying and tryng to post vids on here even youtube but it j6st wont do it ill figure something out soon
Old 06-19-14, 07:55 AM
  #50
TheDamSC
TheDamSC's Avatar
Good write up, pretty straight forward
Old 06-21-14, 06:09 PM
  #51
kolessc400
kolessc400's Avatar
Thank you I finally got a little vid on YouTube
Old 06-21-14, 09:39 PM
  #52
Joey-E
Joey-E's Avatar
Wow sounds pretty good! Should get this on the dyno
Old 06-22-14, 09:54 AM
  #53
kolessc400
kolessc400's Avatar
Ya that will be the next stop with a good tune... I updated my computer now the fic8 needs flashed but when I do it or won't hold the flash
Old 08-03-14, 06:38 AM
  #54
Stretchp2
Stretchp2's Avatar
Default 1uzfe gaining popularity
Amazing write up. I'm not that mechanically inclined. So I will definitely live by your parts list when you post it. So I can give it to my mechanic before we dive into this project. Thanks again
Old 08-03-14, 08:39 PM
  #55
oldManTan
oldManTan's Avatar
that sound!!! GIVE ME SOME MORE!!!!!!!
Old 08-15-14, 11:51 AM
  #56
Boergy
Boergy's Avatar
Hi!
Have you any problems with the clutch bearing T-56? i installed my this week, the clutch works fine, but the new bearing sounds like a old rusty bearing, i´m not happy. But the SC drives much better with MT as with AT
Have you a picture of the bearing that you installed?
Thanks!
Tom
Old 08-20-14, 06:56 PM
  #57
kolessc400
kolessc400's Avatar
Sorry guys i haven't been on here for a while... Stretch the first post on here is a parts list with detailed descriptions... Old man tan will have better videos soon... Boegry no no problems just with the clutch disks slipping under boost, i have even swaped to a kevlar 4 puck clutch and still doing so are you sure it's the bearing?? could it be the transmission,
Old 09-12-14, 03:13 PM
  #58
kolessc400
kolessc400's Avatar
So i have found some small things that but me a little about wireing to neutral with the turbo set up since the ecu thinks it's in neutral at all times it confuses it when it learns driving habbets it starts to lean out some times when letting out of the gas and go into neutral because while in gear and letting out of gas it kinda tracks back on its self while slowing down... So it's trying to do that while going into neutral then you rev it a little and it idles fine again so I'm trying to find first to wire to and experiment with that
Old 03-20-15, 05:19 PM
  #59
kolessc400
kolessc400's Avatar
HI everyone havent been on here in a while... but i have since figured out what was wrong with the clutch... i had found that the pressur plate that i used couldnt hold the under boost... so since then i went with a kevlar 4 puck 3sgte clutch that is rated for 900 whp supposedly but it is holding great and i had a little air in the clutch now i have vacuum blead the sys and now it feels awsome im getting a better tune and bigger injectors soon so now we will be able to test the trans and clutch soon
Old 01-01-16, 03:58 PM
  #60
tenac2215
tenac2215's Avatar
I'm in the middle of swapping my trans right now. I'm wondering, does the speedometer sensor from the auto work on the w58? Is there an adapter or something I need? Or can you just not have a working speedometer if it's manual swapped?
Quick Reply: w58 to 1uz sc400 swap about ready
