Build Threads Details on Club Lexus SC owner vehicles
Tj's 95 SC300 1jz Swap
Old 07-22-16, 07:25 PM
  #241
sc3757
sc3757's Avatar
Subscribed. Very nice build man
Old 07-23-16, 10:00 AM
  #242
kez
kez's Avatar
Niiiice still clean in the bay
Old 07-28-16, 09:29 AM
  #243
kingblack
kingblack's Avatar
Read the whole thread build. Very nice.....very inspirational bro...
Old 07-28-16, 06:19 PM
  #244
tjmhillz
tjmhillz's Avatar
thanks bro. i appreciate the kind words. So i stopped by my friends house and he was finishing up the wire tuck with the custom harness he made.. I also had to send back my Tweaked Patch harness because the wrong connector was on there. I needed it for the 2j and the one that was on there was for a soarer. Which was my fault and Cam@tweak was very cool about it and was able to fix it and that should be done tomorrow and shipped back to me. Car should be fully done by end of next week.
patch harness with soarer connecter but will be fixed with 2j connector. (btw the harness looks really good. ). i have on the harness boost, fuel, wideband, iat and map. i will also be running a 3.5 bar aem map sensor.
Old 07-30-16, 07:43 PM
  #245
oemplusmor
oemplusmor's Avatar
Subscribed for a Jersey build.
Old 07-31-16, 09:24 AM
  #246
tjmhillz
tjmhillz's Avatar
thanks man...what part of jersey are you from?
Old 07-31-16, 12:24 PM
  #247
oemplusmor
oemplusmor's Avatar
I'm near Plainfield not too far from Gonzy. I'm building/restoring a 93 SC with a 1jz vvti, r154, with. TRD lsd. Hope to be done by end of summer. It's been a 2 year build. Same as you I dressed up the motor and resprayed the engine bay.
Old 07-31-16, 03:27 PM
  #248
tjmhillz
tjmhillz's Avatar
Nicee. Gonzy is good peoples. I plan on doing trans swap next spring to either r154 or cd009. What made you go vvti over non?
Old 07-31-16, 03:47 PM
  #249
oemplusmor
oemplusmor's Avatar
Vvti choice came down to budget and goals. I of course wanted a 2jz but a V160 was out of the question due to price. I found a rear sump, tripod r154, 1jz vvti with an aftermarket ramhorn manifold that used the stock turbo all out of a Soarer.
I went over to the Jzx100 Chaser Aussie forums to get more info on the 1jz vvti's and they love these motors. I bought into the hype haha.
Old 08-02-16, 07:05 PM
  #250
tjmhillz
tjmhillz's Avatar
^^nice bro.. Well heres a few more updates. Intake installed, wide band installed, fuel pressure regulator installed, Only thing left is wait for my patch harness(will be here tomorrow) install 12v fuel relay, Install fuel sensor, install gauges, and she will be pretty much done.. long time coming and i cant wait to fire her up..
Old 08-03-16, 05:42 AM
  #251
sc3757
sc3757's Avatar
Looks awesome! who is going to do the tune? And when?
Old 08-03-16, 05:49 AM
  #252
LoveSCs
LoveSCs's Avatar
Awesome man! I know that feeling of anxiousness! Before you fire it up, fill the radiator with coolant (obviously ha) and then pull the hoses off of the firewall going to the heater core and pour coolant down them to completely fill the system. Otherwise you will have a hard time getting your thermostat to open. At least I did anyway and that's what I had to do. Maybe you already knew that or have a different way of starting up, but just figured I'd mention it
Old 08-03-16, 08:49 AM
  #253
tjmhillz
tjmhillz's Avatar
i didn't know that and will give it a try. Learn something new everyday haha
Not sure yet on who's going to tune it. I have a few places in mind though just have to see if they will be avail and also prices.
Old 08-04-16, 09:44 AM
  #254
kingblack
kingblack's Avatar
Is the sc 400 differential that much of a difference from the 300?
Old 08-05-16, 03:03 PM
  #255
tjmhillz
tjmhillz's Avatar
^^im not sure as i will be using the stock 300 diff for now.. heres a few more updates. My patch harness came in with the right connector as well as my wide band sensor and aem fuel sensor. We got the boost gauge installed and now just have to install wide band.
aem wide band sensor
aem fuel pressure sensor
2jz connector for patch harness
Quick Reply: Tj's 95 SC300 1jz Swap
