Build Threads Details on Club Lexus SC owner vehicles
2JZGTE rebuild
Old 12-26-13, 09:12 AM
  #421
JesLet
JesLet's Avatar
I calibrated the Digital Dakota SGI-5 to work with my GM speed sensor and I finally did it! I used my cellphone GPS to match the one on my speedo.
Much thanks to turbodremz for helping
Old 12-26-13, 09:15 AM
  #422
JesLet
JesLet's Avatar
Here's the link for cluster resistor mod and GM 2-wire speed sensor
https://www.clublexus.com/forums/per...or-sender.html
Old 12-26-13, 10:14 AM
  #423
stockhatch
stockhatch's Avatar
Originally Posted by JesLet
Thanks man... heater still no worky... but i could care less... who needs heater in AZ
Hmmm, did you visually check to see if the valve is opening now? If it's not, bypass the vsv and put the vacuum source right on the actuator to make sure the signal and diaphragm are good. If it opens then, you will need to verify the vsv wiring.
Old 12-26-13, 10:15 AM
  #424
stockhatch
stockhatch's Avatar
What percentage adjustment range does that Dakota box support? I am wondering if I can find a box that will adjust signal enough to convert my kph dash to mph...
Old 12-27-13, 07:22 AM
  #425
JesLet
JesLet's Avatar
You can give it a try.. Here's the instruction manual, I calibrated on OUT1 and it won't go down on speed anymore, so i tried OUT2 and i ended up using OUT5.
http://www.dakotadigital.com/pdf/sgi-5.pdf
Old 12-27-13, 09:16 AM
  #426
JesLet
JesLet's Avatar
I got the tach and speedo fixed now I am doing the AIRBAG light. I am trying to diagnose what caused the light to turn on before clearing it.
According to this link, I should clear the airbag light only if i have a code 22.
http://lextech.org/forums/index.php?topic=9.0
When I wire TC and E1 as per instruction, my CRUISE and ABS are blinking intermittently. AIBAG light is still on and not blinking, so this means it is not code 22.
Should I clear it anyway and maybe buy another spare of airbag haha
Old 12-30-13, 08:47 AM
  #427
JesLet
JesLet's Avatar
I tried to clear the airbag light with 3 wires and a toggle switch and light is still on. I tried about 5 times and gave up. I probably take the bulb off grrrrrrr
Old 01-20-14, 10:55 AM
  #428
megomaniac
megomaniac's Avatar
When do we get to find out how much hp/tq your transmission is reliable at?
Old 01-20-14, 03:43 PM
  #429
CatManD3W
CatManD3W's Avatar
More videos of the SC in action.....PLEASE......Lets hear that BW
Old 01-20-14, 08:13 PM
  #430
drifterx27
drifterx27's Avatar
Just went through your thread. A bunch of work for sure. Good job so far, keep it up!
Old 01-20-14, 08:43 PM
  #431
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Love how close the car has come to completion, JesLet! And the AR-5 is shifting and cruising just fine now? You've put an excellent example here for the community to see how it's done!
Old 01-27-14, 02:06 PM
  #432
PoGikoSc4
PoGikoSc4's Avatar
Whut up D!? Any update on your SC brothuh!? i hope all is good man..
Old 01-28-14, 09:42 PM
  #433
JesLet
JesLet's Avatar
Thanks
Yes, shifts like butter. Kept my R154 for rebuild later if i blow this one up.
Still running lol... been busy working on the other car...
No videos, i'd like to though. I have 700 miles on this, pretty satisfied with Aristo ECU, might sell my MAP ECU 3.
Old 01-29-14, 07:59 PM
  #434
CatManD3W
CatManD3W's Avatar
Looks like you got yourself a set of wheels for the SC as well....Varrstoen ES7
Old 02-06-14, 04:38 AM
  #435
gerrb
Super Moderator
gerrb's Avatar
hhhmmm been busy with that IS300 huh ? You can now send me your 2jzgte harness so I can look at it. You said you have an odb1 harness right ? And you have an odb2 car right ?
Don't forget to send that bottle of Patron too. I am out of stock...lmaol. J/K
Damn, before I forget . How is my 2jzge short block ? I hope it isn't rusty yet .
Quick Reply: 2JZGTE rebuild
