Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 03-06-14, 04:38 AM
  #91
97-SC300
97-SC300's Avatar
cant wait to see the BW turbo next to this beauty
Old 03-06-14, 05:44 AM
  #92
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
What size BW did you decide?
Old 03-06-14, 08:15 AM
  #93
CatManD3W
CatManD3W's Avatar
S366 .91 A/R Divided housing
Old 03-06-14, 08:22 AM
  #94
CatManD3W
CatManD3W's Avatar
Me too......I havent decided yet but I am thinking of getting the compressor housing powdercoated black to match the valve covers and intake manifold....
I cant wait to see your BW in your bay as well man...
Old 03-06-14, 08:26 AM
  #95
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Excellent turbo man. Nice choice. Same as mine. You will love it.
Old 03-06-14, 09:02 AM
  #96
CatManD3W
CatManD3W's Avatar
When does boost start coming on...and when do you hit max.....i.e what is the rpm range? It may be a little sooner with the 2jzgte than your 1jzgte
Old 03-06-14, 04:27 PM
  #97
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Yeah it will be sooner on yours than mine. I start hearing the whistling around 3K, hit full boost around 4600 rpm by my gauge. This is pretty close. With my rev limit set at 7500, gives me 3K in full boost and the long R154 tranny helps me stay in boost longer. On yours should be around 3500 or 4K with stock cams. This is a guess.
Old 03-07-14, 03:39 PM
  #98
CatManD3W
CatManD3W's Avatar
Got some good amount of work done over the past few nights...
ARP head studs installed....Thanks 1JZPWRD
Brand new OEM TT Headgasket installed...
Head is on and torqued down....
Also installed motor mounts and brackets....oil cooler...and V8 tundra oil filter
Old 03-07-14, 06:58 PM
  #99
lilSCsteve
lilSCsteve's Avatar
Nice, I knew you were going to use the Tundra oil filter...lol but serious it's looking good!
steve
Old 03-07-14, 07:42 PM
  #100
CatManD3W
CatManD3W's Avatar
steve
Only the best parts for this build....no holding back...
Old 03-08-14, 01:29 PM
  #101
CatManD3W
CatManD3W's Avatar
Since it was nice out today decided to paint a few engine trim pieces...
Also hit the spark plug cover with Toyota Factory color Desert Sand Mica...it is very close to Sandstone Beige.
I noticed the car had these Denso Iridium VK20 spark plugs in it today when I was cleaning up my work bench didnt take notice when I took them out...
These appear to be Japanese specific spark plugs...Found this info on them
DENSO IRIDIUM TOUGH features :
- Denso Iridium Power global performances.
- 0.4mm diameter Iridium Center electrode.
- Platinum chip on ground electrode.
- Last 100 000km (5 times the classic spark plugs on normal use).
- Less fuel consumption (Up to 5%).
- Better acceleration / More stability from ignition.
- More reaction from the engine.
- Cleaner combustion / Less unburned fuel.
- Optimized compressions.
- Horsepower slightly increased.
Old 03-08-14, 01:36 PM
  #102
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Good information to know about those types of plugs. More progress. Little beats none. What kind of black paint did you use?
Old 03-08-14, 01:47 PM
  #103
CatManD3W
CatManD3W's Avatar
I had leftover high temp engine enamel by duplicolor...same color I painted block
Old 03-08-14, 02:59 PM
  #104
97-SC300
97-SC300's Avatar
Man this thing is coming together quick! I may have to stop by and check it out one of these nice weekends
Old 03-08-14, 03:58 PM
  #105
CatManD3W
CatManD3W's Avatar
For sure man....I could use some help putting the motor in......Since you got experience doing it....Let me know when you wanna come to Pittsburgh
Quick Reply: CatManD3W SC300 Ongoing Build...
