Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 05-05-15, 08:22 AM
  #526
8052JZ
8052JZ's Avatar
Rear end will be fine.. tt auto diff at 754hp here and no problems...
Old 05-05-15, 08:32 AM
  #527
CatManD3W
CatManD3W's Avatar
Yea im not worried...the stock SC300 diff is literally the only thing left in the drivetrain that I have not yet replaced..
Old 05-13-15, 11:57 AM
  #528
CatManD3W
CatManD3W's Avatar
Just got back home from vacation today....I had ordered an r154 rear output shaft seal and an w58 rear output shaft seal right before I left..
I got both just to see which one creates a tighter seal(w58)....and to have a backup(r154)...
W58(Left) R154(Right)......I thought it was weird that w58 seal doesnt have any grease on it and the r154 does....
Will be installing the w58 and keeping the r154 as a spare....
Old 05-19-15, 10:54 AM
  #529
CatManD3W
CatManD3W's Avatar
Hey guys I currently working it out with the seller for the soarer r154 issues I have ran into..
The seller and I both agreed to a deal and I am willing to give the transmission another shot
I am taking the tranmission back to freed engineering this Friday to have all the seals replaced.....I will be there with Ben Freed and will be able to see the inside of the case and everything that has been done to it..
Upon arrival at Freed the seller will have an MK3 Front Shaft and Gas money waiting for me....
All the above things are going to be at no cost to me...
I plan to start re-installation when I get back home on Friday and plan to take her out on Saturday...
Will update as I progress
Old 05-19-15, 06:24 PM
  #530
HiPSI
HiPSI's Avatar
Glad you finally found a happy resolution!
Old 05-19-15, 08:51 PM
  #531
CatManD3W
CatManD3W's Avatar
Thanks man....fingers crossed that the leaking will be fixed after being serviced by freed
Old 05-21-15, 05:43 AM
  #532
97-SC300
97-SC300's Avatar
Glad to hear it is being resolved!!!!!!
Old 05-21-15, 07:56 AM
  #533
CatManD3W
CatManD3W's Avatar
Thanks Man...I need to get the SC put back together and have it as a DD for a week while I do a clutch job on my tacoma...
Old 05-21-15, 10:16 AM
  #534
Ali SC3
Ali SC3's Avatar
well if you are doing a clutch job might as well throw a 2j in the tacoma. it would be really fun =)
I have heard the 3.4 supercharger has some kick too on another note.
Old 05-21-15, 02:34 PM
  #535
CatManD3W
CatManD3W's Avatar
I have thought about it....believe me it is a direct swap all i need to do is remove the r150f bellhousing and put a 1jz bellhousing on and get custom motor mounts....
But the 5vzfe is a pretty stout motor.....plus it is a 3.4 liter V6......they have been proven to make a lot of power.....
I may try out the cxracing turbo kit that is out....I would just purchase the exhaust piping kit and build the rest myself
Here is the kit: http://www.cxracing.com/mm5/merchant...Category_Code=
Old 05-21-15, 04:46 PM
  #536
CatManD3W
CatManD3W's Avatar
Removed bellhousing today to get it ready to be serviced by freed engineering tomorrow and found yet another problem....
Front bearing retainer is cracked...
Old 05-22-15, 07:50 PM
  #537
CatManD3W
CatManD3W's Avatar
Well guys I am back from getting transmission being serviced at freed......ended up splitting the case wide open to make sure everything was good inside......
Verified that it did indeed have all brand new gears...you can tell because they still have paint marking on them....as well as the billet forks..
Closeup of billet fork...
Freed installed both front and rear seals....and sealed the case back up for.....I also had the front bearing retainer swapped out with an unbroken one......Everything should be good to go
I was expecting to be getting the MK3 front driveshaft when I arrived at freed but something happened with the shipping according to the seller....I should have it by early next week
Old 05-23-15, 03:50 PM
  #538
Maximo018
Maximo018's Avatar
Man this is an awesome build. Glad to see you're still moving forward. Sucks about the R154 issue vs the W58 seemed to be fine except them limiting you on power. Looking forward to more.
Old 05-23-15, 05:23 PM
  #539
CatManD3W
CatManD3W's Avatar
The W58 Blew up.....didnt really have a choice in the matter...
Old 05-23-15, 08:07 PM
  #540
HiPSI
HiPSI's Avatar
So is the verdict of the issue related to the driveshaft length putting pressure on the box? Hopefully its a simple as that, correct the driveshaft and all problems go away.
Quick Reply: CatManD3W SC300 Ongoing Build...
