CatManD3W SC300 Ongoing Build...
#411
Installed 15mm spacers on the rear.....effectively making them 18x8 +15...Ending up making them perfectly flush on the rear...and enough room to fit a 255
I am gettting new tires installed....going with a 245/35 Front and a 255/40 Rear...and adding a 15mm spacer up front
The cold weather is making it impossible to get any traction.....but its more fun!!!
#413
#414
Ultimately I think I will use these 350z touring wheels and 15mm spacers all around for a track setup at some point...with Hoosier R6 racing tires
#415
I have a dyno session scheduled this Friday the 21st....Will post up the results after session is completed...
Engine is stock with single turbo:
Aristo 2JZGTE w/JDM cams
Aristo ECU
440cc w/ Supra TT fuel pump
T4 Twinscroll manifold with TIAL 44mm
BorgWarner S366 0.91 A/R @ 14psi(wastegate only)
Full 3" exhaust and downpipe
FMIC 30x12x3 Core w/ 3" piping and Tial 50mm
I am hoping I will break above 400hp....Stay tuned for results
After the session the SC will be put away for winter
Aristo ECU
#416
I've been trying to get on the dyno....but it has been tied up with anoter build......Plan on trying to get the SC in soon
But in the mean time......Bought myself a set of wheels for the SC...
XXR 521 in Machined Finish (NLMotoring Exclusive Edition).......18x8.5 and 18x10 with +25 offset....I test fitted the front and it clears the LS400 BBK with ease....
I am going to be running 245/35/18 and 275/35/18......
The rivets are removable on the wheels as they are only for looks.....I thought about picking up a gold set and I am also going to get Muteki SR48 tuner style lug nuts in gold to match.....
On to the wheels:
Rear Step Lip:
On to the wheels:
Rear Step Lip:
#417
Over the weekend I got these 245/35/18 Goodyear Eagle F1 tires from my buddy for cheap and got them mounted and balanced on the 2 front wheels...
I test fitted one of the front to see how well it filled out the fender wheel area as well as the look of them...
I am awaiting lexus center caps, hub rings, and muteki sr48 lug nuts in anodized gold
Also need to order the 275 tires for the rear.....car is parked for winter now so I am in no rush with things
I will need to adjust the coils once I get all the new 4 wheels and tires on....
