Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 05-08-14, 02:45 PM
  #226
lilSCsteve
lilSCsteve's Avatar
Great run bro! Did you get the speedo worked out?
steve
Old 05-08-14, 03:24 PM
  #227
CatManD3W
CatManD3W's Avatar
steve
No still havent yet....Im going to get a new sensor and see if it works...but it is a low priority....Dont need no stinking speedometer......
Old 05-08-14, 05:09 PM
  #228
95SC3T
95SC3T's Avatar
How did you delete the heater valve? and is your heat still functional?
Old 05-08-14, 05:11 PM
  #229
CatManD3W
CatManD3W's Avatar
I just looped the hose from back of block to metal coolant pipes for oil cooler.....I eliminated heater all together....I was taking off the hoses and it pulled the metal pipe right out of the heater core....You will still get the radiant heat from the engine..
Old 05-08-14, 05:13 PM
  #230
CatManD3W
CatManD3W's Avatar
Originally Posted by Tabaka
What EMS do you have?
Im running factory Aristo ECU......
Old 05-08-14, 06:01 PM
  #231
Tabaka
Tabaka's Avatar
Excellent, I'm doing the same. It sounds like we have very similar builds. The only major differences that we have is the actual engine . I'm running the GE with a BWS300, 44mm precision WG, Blitz BOV, Southbend clutch, XS Power FFIM, Q45 TB, Aristo ECU, RC 440's, and an ebay mani. I'll install the valve covers when I find a set that doesn't cost more than an entire GE motor I can't believe people want $400 for a damn spark plug cover lol.
Excellent build, I'll check in from time to time. What exhaust are your running?
Old 05-08-14, 06:11 PM
  #232
CatManD3W
CatManD3W's Avatar
I bolted my downpipe up to stock exhaust for now....going to do full 3" soon
Old 05-08-14, 06:16 PM
  #233
CatManD3W
CatManD3W's Avatar
I thought about going NA-T but for the cost to make it right...would have been better off going GTE to begin with...plus my JDM Aristo GTE motor only has 83,000km on it which is about 50,000 miles compared to my old GE that had 170,000 miles
Old 05-09-14, 08:17 AM
  #234
lilSCsteve
lilSCsteve's Avatar
Good point, plus I like that fact you were able to drive and pick out your own engine prior to purchase. Smart move, I just wish there were move engines available near me-I'd do the same!
steve
Old 05-09-14, 09:18 AM
  #235
Halon
Halon's Avatar
I like the NA-T approach, only thing I don't like is the intake mani situation. To each their own though, really can't go wrong with a GTE.
Old 05-09-14, 09:35 AM
  #236
CatManD3W
CatManD3W's Avatar
steve
Yes it was much easier for me as I was able to pick out the engine in person....
Old 05-09-14, 10:16 AM
  #237
CatManD3W
CatManD3W's Avatar
Give you guys an idea of what it cost to do the swap....
NOTE: I DID ALL LABOR AND WIRING HARNESS WORK MYSELF
• 2jz Motor Mounts - $69.99 each x 2 - $139.98
• 2jz OEM Timing Belt - $32.00
• 2jz OEM Serpentine Belt - $25.00
• 2jzgte Throttle Cable (Supra) - $68.00
• Transmission Output Shaft Seal - $10.25
• Transmission Mount W58 - $59.50
• SC300 Manual Shifter Boot - $58.00
• FIPG Black - $13.50
• 2jzgte Ventilation Hoses - $16.99
• 2jz OEM Thermostat - $21.00
• Toyota OEM Engine Gasket Kit (Supra) - $399.99
• Toyota OEM Oil Pump (Supra) - $149.99
• Toyota OEM Water Pump (Supra) - $133.25
• Toyota OEM TT Denso Fuel Pump Used - $75.00
• JDM 2jzgte Engine - $2,500.00
• Competition Clutch Stage 4 1620 - $345.00
• CX Racing Intercooler Kit - $250.00
• Innovative Wideband 3844 MTX-L - $150.00
• Innovate D3 3816 Boost Gauge - $75.00
• Borg Warner S366 0.91 A/R Twin Scroll - $650.00
• Oil Feed/Return Lines - $120.00
• Tial MV-R 44mm Wastegate - $350.00
• Tial Q 50mm BOV - $250.00
• 2jzgte T4 Manifold - $300.00
• 2jzgte Downpipe - $150.00
• Marmon Flange Kit - $50.00
• K&N RC-4680 - $50.00
• 4” Intake - $50.00
• Misc Welding - $200.00
• Misc Powder Coating - $150.00
• 2jzge rear sump oil pan - $150.00
• Redline Diff and Tran Oil - $15.00 qt x 5 = $75
• Harbor Freight Engine Hoist -$200.00
• Harbor Freight Engine Stand - $60.00
Total: $7335.00
I did sell off some of my original GE and Aristo Parts:
• 2jzge Engine – Sold for $500.00
• Aristo Turbos – Sold for $160.00
• Aristo Misc Parts – Sold for $100.00
• 2jzge 5 Speed ECU – Sold for $90.00
• 2jzge OEM MAF – Sold for $35.00
Grand total so far: $6450.00
Old 05-12-14, 08:27 AM
  #238
CatManD3W
CatManD3W's Avatar
Interior door panels are almost finished.....
Old armrest vs. new
I am not sure what I am going to do with the passenger side panel......It is to broke to repair..I have tried to repair it with fiberglass but it is broke in a really bad spot where the plastic is really thing
If anyone has the lower door trim panel that goes around the speaker and where the armrest is.....I only need that piece color doesnt matter as I will be wrapping it with new vinyl...
This is what happened to mine....
Old 05-12-14, 09:29 AM
  #239
gerrb
Super Moderator
gerrb's Avatar
With labor cost on swap and wiring harness labor cost , that could have been an easy $10k project !
Old 05-12-14, 11:43 AM
  #240
CatManD3W
CatManD3W's Avatar
Yep....Im really glad that I did the harness myself with a little bit of some extra help.......
Quick Reply: CatManD3W SC300 Ongoing Build...
