Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 04-01-14, 06:15 PM
  #151
drifterx27
drifterx27's Avatar
Looking clean man. That Toyota coolant had me like WTF when I had to buy a bottle too.
Old 04-01-14, 06:37 PM
  #152
CatManD3W
CatManD3W's Avatar
Thanks....Its not really that bad if you think about it.....You only need 1 gallon of the red and then mix it with distilled water...
The premixed stuff is $20 a gallon and you would need 2 of them
Old 04-03-14, 08:10 AM
  #153
CatManD3W
CatManD3W's Avatar
Turbo side is all finished up.....
Very tight fit....I wrapped the oil return hose with DEI cool wrap just as an extra precaution...
Brand new radiator installed....
Old 04-03-14, 09:41 AM
  #154
97-SC300
97-SC300's Avatar
Man this thing is coming along so well, still no one replied to the SF thread about getting you that fan blade and shroud sorry man
Old 04-03-14, 09:47 AM
  #155
gerrb
Super Moderator
gerrb's Avatar
with the price they are being sold used..I suggest go to Curt of Elmhurst Toyota and get them new.., price difference wont be a lot .
Old 04-03-14, 02:28 PM
  #156
CatManD3W
CatManD3W's Avatar
Yea...I figured I would give it a try but looks like I am going to have to buy them new
Old 04-03-14, 05:11 PM
  #157
CatManD3W
CatManD3W's Avatar
Hey guys I attempted to start the car today...First ran into a bad battery and replaced that with new....I made a video please watch and let me know...Im thinking it isnt getting spark but im not sure...
https://www.youtube.com/watch?v=iaVg...ature=youtu.be
Old 04-03-14, 05:19 PM
  #158
97-SC300
97-SC300's Avatar
I would pull out one spark plug and while still connected to the coil crank it to see if you have spark.. If you do smell inside cylinder with plug out to see if you smell fuel if you smell fuel and see spark than it's something else.
Old 04-03-14, 07:09 PM
  #159
gerrb
Super Moderator
gerrb's Avatar
^^^ +1
Catmand3w - sorry missed your call..been busy , had to bring my son in law to the hospital for an emergency and am still waiting here. As 97-sc300 had said, check if you smell fuel or have spark first . If you have both then it's something else.
Video sounds like you either have no fuel being injected or no spark ...
Old 04-03-14, 08:00 PM
  #160
CatManD3W
CatManD3W's Avatar
Checked plugs.....I am not getting any spark....I turned key to on position and checked Coil #1 and I am not getting any reading on multimeter.....Also I cannot smell fuel when I remove the spark plug...
Not getting any spark or fuel into cylinders.....
Also I wanted to indicate that my intake manifold is powdercoated could there be a grounding issue?
Looking for some advice on where to start troubleshooting...
Old 04-04-14, 11:52 AM
  #161
Ali SC3
Ali SC3's Avatar
Are you using the gte ecu or a standalone right now? If you have the grounds connected to the intake manifold they should be connected to bare metal parts, they will not generally ground through a powder coat, so it depends where you bolted those couple grounds to.
Old 04-04-14, 03:24 PM
  #162
CatManD3W
CatManD3W's Avatar
Thanks....I have double checked the grounds and they are good....I also checked continuity between t all 6 injectors to the 80 pin and they are all good. Checked cam and crank sensors for continuity..they are good...I know my wiring is good....
Sending my ECU off to Gerrb so he can check it in one of his cars....
Old 04-06-14, 02:26 PM
  #163
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Any more updates, after you pulled the harness out?
Old 04-06-14, 06:20 PM
  #164
CatManD3W
CatManD3W's Avatar
Yep...I think I figured out the problem but for safe measure sending it off to have another set of eyes take a look at the harness for me...
Old 04-08-14, 09:47 AM
  #165
CatManD3W
CatManD3W's Avatar
Got the lip mounted and sanded....Just need to add some paint to it...I kinda like the look of the bolt heads on the lip gives it a nascar look lol...
I am going to finish the lip with roll on bed liner that I have leftover from my truck....It goes on thick and has a textured finish so the lip doesn't have to be perfectly smooth...
Quick Reply: CatManD3W SC300 Ongoing Build...
