2002 gs 300 troubles with check engine vsc on vsc off
Hello everyone,
I am a new member and am having trouble with my 2002 GS 300. It tripped a P1349 code first. I pulled the vvt oil filter and cleaned it . I unhooked the neg terminal on the battery and reset the computer. I drove it and the check engine, VSC ON, and VSC OFF all came on again. I checked to see if the codes changed and I got C 1256, C1223, CC1201, P1349, andP1346. When I come to a stop sign it will quit and I have to restart it. It does it every time I stop, and sputters some under 40mph. Has anyone else had these codes come on together with the warning lights.
jwils6128n
jwils6128n
I don't think this is the right place for this post, but I do have the same issue and am new to this forum. 2000 gs3. Mine is intermittent sometimes it does not come on and sometimes it does. It does sputter a little when pulling away from light.
QLex300 (02-15-22)
Any fixes on this? I have the same issue reoccurring on my 2001 GS300, and I have changed all o2 sensors, Mass Airflow Sensor, Crank Shaft Solenoid, VVTI Sensor and the problem persist. Please help.
QLex300 (02-15-22)
Hello everyone,
jwils6128n
jwils6128n
Have you figured out the issues
Thanks
