My slooowww build thread. Take 2. - Page 3 - Club Lexus Forums
Thread Tools Search this Thread
Old 07-17-13, 10:40 AM   #31
Ali SC3
Ali SC3's Avatar
yeah you guys should be fine around that power level, I have been running 14 psi for a while now the w58 can take it but just give it that extra second between gears, if you have to downshift into boost to take off.. do that shift slowly don't worry you will catch back up once you are in gear.
the shaft play sounds fine, try not to spin it a whole bunch if you have to put some oil in the center section and then the play should decrease also.
Manifold wise I opt for the universals although the driftmotion one is not much more coin. since you are going coil on plug, you won't have to worry about distributor clearance, which is the main problem with the universals. many use them and I haven't seen any turbo's fall off a JZ on here yet.
Ali SC3 is offline   Reply With Quote
Old 07-17-13, 11:49 AM   #32
ashtray
ashtray's Avatar
Quote:
Originally Posted by scott101 View Post
i might have missed it but what coil packs and injectors are those?
thanks
scott
The injectors are RC550's and the coil packs are the 2jzge VVT-i's.
Good to know your w58 is holding up well after so long. Ya the shaft play is seriously negligible and once oil is in it that should help. It's sitting in a bag in a box so I aint messing with it until I decide to paint the compressor housing. Might see if I can get around to the GTE and COP distributor delete this weekend just to have that out of the way and later on just bolt everything up. Been busy lately. Is it a bad idea to put a compressor housing in an oven to bake paint onto it?
ashtray is offline   Reply With Quote
Old 07-17-13, 12:43 PM   #33
Ali SC3
Ali SC3's Avatar
you mean the hotside or the turbine housing, don't think you want to paint the front of the turbo =)
yeah as long as its just the housing, I wouldn't stick the whole turbo in there or anything like that but those parts see temps much hotter than an oven on a regular basis, so you should be fine.
Some just use the first start up as the bake, then let it cool down, and that cylcles is but its not as nice as doing it the right way.
good luck with getting the housing off also, thats where mileage on the turbo can come into play if its never been opened before, some come off easy, some you gotta use a vice on the center cartridge and whale on it with a deadblow hammer while torching it from various angles, but from looking at the turbo it looks in good shape it should be more the comes off easily type.
Old 07-17-13, 12:47 PM   #34
ashtray
ashtray's Avatar
No I do want to paint the front haha. I wanna have a black theme going on. Plus every turbo looks the same, they're all the same gray color or chrome. I'd like to do something a little different haha I dont think I'll do anything to the exhaust housing...that reminds me, one bolt is missing on the exhaust housing, do I contact Precision for this bolt? It's a bolt that holds the exhaust housing to the actual core.
Old 07-18-13, 08:05 AM   #35
Ali SC3
Ali SC3's Avatar
I see, yeah that should be fine just take it easy with the heat. the bolt is probably a m8 or m10 or something like that, you can contact them or just take the one next to it out and find a copy at ace they usually have all the Metric bolts, match both the thread and length and go shorter if you have to rather than longer.
Old 07-18-13, 09:41 AM   #36
lookEVO
lookEVO's Avatar
Just go to the hardware store and get one. Dont bother calling precision. It will be way cheaper and take a lot less time.
lookEVO is offline   Reply With Quote
Old 07-18-13, 10:16 PM   #37
ashtray
ashtray's Avatar
In the oven curing as I type this. Will post final results when put back together.
Quote:
Very good very good.
Old 07-19-13, 01:30 AM   #38
ashtray
ashtray's Avatar
Before
After
Came out exactly as I wanted with a Caution red hot color. It's simple VHT 2000 degree flame proof header paint with a silica/ceramic contents. Let us see how long it lasts once on the car. Cured it exactly as it states on the can.
Old 07-19-13, 01:30 AM   #39
jwin
jwin's Avatar
Man it looks really good.
jwin is offline   Reply With Quote
Old 07-19-13, 10:36 AM   #40
lookEVO
lookEVO's Avatar
That looks great. Makes me wanna do it now.
Old 07-23-13, 11:28 AM   #41
ashtray
ashtray's Avatar
Quote:
Thank you sir
Do it!
So I decided to not do the TT headgasket nor the ARP headstuds. I'm only running 12 psi for now and with a stable set up and tune coming from the GTE ecu, I'll trust that my current headgasket will be fine. When I upgrade the tranny and plan for more boost, then I'll do the headgasket and arp headstuds. I'd rather not open up the motor seeing as how I've been MORE than diligent with my oil changes and regular maintenance. I trust the headgasket is in fine shape and more than ready to handle 12 psi.
Old 07-23-13, 12:38 PM   #42
Ali SC3
Ali SC3's Avatar
at 12 psi it should be fine, and man that turbo did come out nice!!
Old 07-23-13, 01:35 PM   #43
Tabaka
That's one fire engine red turbine, looks great!
I decided to move forward with the headgasket and ARP studs. I know it's going to add another $265 to my build, but I'd rather just get it done rather than wait for it down the road. Plus this will be the opportunity to change out a few seals like the cams. I might just rip out those cam gears for some nicer looking ones anyways
Tabaka is offline   Reply With Quote
Old 07-23-13, 06:33 PM   #44
ashtray
ashtray's Avatar
Hopefully 12 psi is okay. I'd HATE a blown hg. But oh well we'll see what happens.
See I just had a timing belt change along with cam seals as well. I'd hate to open up the motor now.
If anything I'd get a shop to do it...
Old 07-23-13, 11:40 PM   #45
Joey-E
Joey-E's Avatar
GL on the build coming up man Rarely see a painted turbo painted like that looks good
Joey-E is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2JZGE Na-T TT Ecu Mod Ali SC3 SC- 1st Gen (1992-2000) 3364 Yesterday 09:37 AM
Kahn's USDM 2JZGTE swap thread (aka The "Not Easy" Way) KahnBB6 Build Threads 326 03-21-17 02:57 PM
Project Snail's Pace SCereal Build Threads 100 08-03-15 06:31 PM
New Guy intro SlvrGS300 GS - 2nd Gen (1998-2005) 31 02-06-11 07:29 PM
NA-T Build Thread: 1996 SC300 mteele Performance & Maintenance 8 06-24-09 05:51 AM
Tags
budget, build, ceramic, na-t, paint, red, vht
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
