My 2jzgte swap - Page 4 - Club Lexus Forums
My 2jzgte swap
Thread Tools Search this Thread
Old 05-06-13, 12:26 PM   #46
KeyKeeper
KeyKeeper's Avatar
Where you at in ATX? I wanna see this car in person. Im about 20min north of Round Rock. Lemme know. Im looking at snagging a gte online as well. I'll go through it first though and replace all of the seals and oil pump before I set it in my car. My lil ole GE still runs great..for now.
KeyKeeper is offline   Reply With Quote
Old 06-03-13, 05:32 PM   #47
vbieds
vbieds's Avatar
Just an update, did a headlight retro with fxrs, painted the shrouds. I love it! I also installed a turbo timer for peace of mind. Car is running great, now its time to do some bp upgrades!!!!
vbieds is offline   Reply With Quote
Old 06-03-13, 09:47 PM   #48
gambino19
who did your wiring
gambino19 is offline   Reply With Quote
Old 06-05-13, 06:38 PM   #49
0flav85
nice build dude, doing the same swap, need to get it done asap, had my engine for almost 3 years now. what did you do about the throttle cable and did you use the gs shift link that connects the bottom of your shifter to transmission?
0flav85 is offline   Reply With Quote
Old 06-16-13, 02:48 PM   #50
vbieds
vbieds's Avatar
Quote:
Originally Posted by gambino19 View Post
who did your wiring
I did all of my own wiring.
Old 06-16-13, 02:49 PM   #51
vbieds
vbieds's Avatar
Quote:
I used a supra throttle cable. I reused the old link on the aristo tranny.
Old 07-19-13, 02:55 AM   #52
gambino19
did come up on any problems or was it pretty straight forward? i know the edu is in the engine bay so you dont have to extend it. did you have to change the pinouts on the body plugs to make the gauges and interior stuff work? if so can you share this info?
Old 07-19-13, 03:02 AM   #53
gambino19
how long did it take you do the swap?
Old 07-23-13, 05:33 AM   #54
0flav85
Quote:
when you say old do you mean the one from gs becausemy engine didnt come with the aristo one and im worried if the gs will work or not with the aristo tranny.
Old 07-24-13, 03:28 AM   #55
gcam77
Did you swap out the JDM turbos with USDM turbos??
gcam77 is offline   Reply With Quote
Old 08-06-13, 10:01 PM   #56
vbieds
vbieds's Avatar
Quote:
No. They are jdm turbos.
Old 08-06-13, 10:03 PM   #57
vbieds
vbieds's Avatar
[IMG][/IMG]
[IMG][/IMG]
Old 08-06-13, 10:05 PM   #58
vbieds
vbieds's Avatar
Aristo cable couldnt be used.
Old 08-06-13, 10:07 PM   #59
vbieds
vbieds's Avatar
No changes to pinouts. Only ran one line for the tach. Swap took me 12 hours off and on by.myself. my first engine I ever pulled....
Old 08-12-13, 01:15 PM   #60
0flav85
I have a question about the swap, are all models required to move pins on the gray plug, because I didnt have a shift lock when i turned it on. the car runs and everything. I have several lights on and I know i have to pull the vcs bulbs but my windshield washer light is on but I topped it off, my oil light is on and when I go over a certain rpm my check engine comes on and stays on until I shut off the car and its off again when i turn it back on also my ECT starts flashing when my check engine light goes on. once the check engine turns on. the car shifts early and down shift quick when i get off the gas. It seems to bog if I floor it and when that happens it feels like im just making noise and not really going anywhere like a civic lol. I havent run my tach wire yet so cant really reference any rpms but if i floor it and it reaches a certain rpm it will bog and i wont accelerate. Are these the simtons of limp mode and if so wich wires do i move to and where do they go on the plug. I still need to run my tach line will that fix any other lights on the dash or just make the tach work? And do i just cut and soder the wire to where it goes on the body plug? thanks again for the help.
Thread Thread Starter Forum Replies Last Post
Some proper pics of my rebuild TTurboPimp GS - 2nd Gen (1998-2005) 50 02-19-15 01:14 PM
CA Original WALD DUCHATELET VIP 1Gis300 1Gen IS300 Classifieds (98-05) 0 04-13-14 01:25 AM
92 sc400 sub replacement farva812 Build Threads 4 03-22-14 12:24 AM
My 2jzgte None VVTi swap is almost complete 1Gis300 IS - 1st Gen (2001-2005) 5 06-23-13 09:47 PM
2010 GS 450h pics, 100% non-modified Teocali GS - 3rd Gen (2006-2011) 21 04-24-13 03:22 PM
Tags
2jz, 2jzgte, aftermarket, aisin, clublexus, gs300, gte, intercooler, is300, jdm, lexusis3002jzgteswapintercooler, pump, sc, stock, swap, turbo, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
