Jay's 93 SC300 2JZGTE, Interior Redone by your's truly, 1JZPWRD !!
#166
1JZ Single SC400
With this 5K head, Ferrea titanium valves and springs, Waldon 750 pump, 2100cc injectors, -8 feed line, HKS management system, Comp ball bearing turbo (unsure of size), block is built .040 with JE pistons and rods, and E85 its very torquey. This car has two tunes as well, one for 93 and the other E85.
Jay correct me if I am wrong with this info, just going what I remember....
#167
That turbo is A comp turbo, housing stays the same only change the internals, When it was installed it was a 67 triple ball bearing, hp comes from alot of different factors. But doesnt matter how many hp it make if i cant put it down. The engine is a fully built 2jz bored .40 over, Billet and arp parts, Cleaves race bearings, "SHOP" 2jz cnc port and polished head with jun valve train, the largest injectors possible opened up a lil more, magna fuel 750 fuelpump, All braided lines, E85 fuel setup, hks pro f con engine management, last bulid it put down 840 on on 26lbs and 650 on low boost. This time we fixed all the little things and kurtis took his time and built it right.
#172
1 Post
lol while i was reading this . just remove the Logo that will do for now. keep up the good work bro. hopefully next time yall are in town. ill have my SC ready.
#173
1JZ Single SC400
Thanks man. I will be painting the dash this evening. Rain is almost out if here in my area. Then the door pods then the rear 6x9 cutting and fitting.. it is a pain to do this but well worth the time and effort for some good sounding tunes. These will be either Alpine S models or Polk Audio's. I think either will be an improvement over the stock sound quality of the 90's.
#174
1JZ Single SC400
I ordered several parts this evening.
Driver side window trim in black
Driver side seat trim, still trying to locate the passenger side one
Driver side vent, still trying to find the center and passenger side ones
Black center console with lid
Black seat backing for both seats
Climate LCD screen
Blue needles from Lextech
Climate control backlighting from Lextech
Center cupholder for console, the one I had is junk, thought I coould get it to work.
More pictures later, gotta pull the SC in the garage and get to work!
Climate LCD screen
#176
1JZ Single SC400
I ordered it locally from a car paint and body shop, that strictly sells car paint. They are called Moore's Paint, number is 256-534-1575, anyone who answers the phone can help. They also do a military discount, 10%. They might be able to ship it to you, for a small fee. They can get whatever finish you want.
Made more progress today.
Painted the passenger side airbag, two coats:
Four coats and final product:
Painted the fold out cupholder:
The finish product installed:
Removed the factory subwoofer, Jay has decided to put in a all out stereo in :
Prepped the dash for the paint, I had the blower heater propped up in the passenger side door, raising the temperature inside the car, so the SEM paint would adhere:
While the first two coats were drying:
If there is any overspray, which I doubt there is, I will remove with a razor blade in a single direction. Don't worry Jay, I wasn't going to leave the cardboard in the window, although the sticker is kinda distracting.
Prepped and painted the passenger side seat and all the plastic pieces. I also removed the under plastic piece for the headrest and painted it as well.
#177
You painted your dash the same way I painted mine lol. Forget trying to remove that thing, way too many bolts and stuff in the way to make you crazy. The rest of my upper black interior is OEM pieces that I paid A LOT of money for. Wish I would have just sprayed SEM and saved a ton of cash. Oh well, live and learn.
#178
1JZ Single SC400
