2GSC300 Sc400 (Blk Mamba) build chronicle
#46
The next thing that was done was to wire up the Greedy E-Manage Ultimate. This will allow for the deletion of the airflow meter and proper tuning. We are also installing an Innovative Wide band to keep everything balanced. So far, the car runs on a simple base tune, but will see the dyno when all the mechanical stuff is completed. Tuning will be done by Doc at FAAS Racing. He also did the base tune.
#47
So the car went over to the transmission shop for a valve body upgrade. That means we are on the final leg of the mechanical part. The shift points have to be programmed in as well as the E-manage. Both will be done as soon as the fuel pump and boost controller are installed. Then its time to dyno this bad boy.
Sphan519
03-16-15 02:00 PM
