Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 10-06-16, 03:19 PM
  #1081
8052JZ
8052JZ's Avatar
After honing out the hub, I was able to drive the hub on with oil on the crank and using the bolt with a long breaker bar. Took some effort to get it on but it went on smoothly.
Old 10-31-16, 09:41 AM
  #1082
8052JZ
8052JZ's Avatar
Moving slowly but started to move things over to the new motor. The old "blown up" motor still needs to be gone through to see what exactly failed
Turbo manifold will get freshened up. Ill be welding and replacing the current 1" T4 spacer to eliminate one sealing surface for the turbo. After welding, ill send it off to get surfaced to insure the sealing surfaced or nice straight.
Then I decided to go with a wrinkle black engine this time around. I love the polished looked but the maintenance to keep it nice an clean is more than I care for. I plan to keep the fuel rail, cam gears, pulleys and stainless steel lines nice and shiny to give it some contrast to the wrinkle black. Valve covers, Intake manifold, catch can and and cold side piping will be wrinkle black.
Old 10-31-16, 01:57 PM
  #1083
Golden95SC
Golden95SC's Avatar
Awesome car and amazing progress! can't wait to start mine
Old 11-08-16, 03:12 PM
  #1084
8052JZ
8052JZ's Avatar
Waiting on parts.. So I decided to paint the bay. Came out fairly good using deplicolor semi gloss engine paint. I used the fan inside the bay to pull over spray away from the spraying area and it worked our really well.
Old 11-09-16, 07:53 AM
  #1085
CatManD3W
CatManD3W's Avatar
I would highly advise on getting the pieces powdercoated.....since you have the time.....Paint doesnt really hold up well...
I did my pieces a few years ago in texture satin black and they still look the same as they did when I put them on....
Old 11-09-16, 09:22 AM
  #1086
8052JZ
8052JZ's Avatar
I powder coat all of my parts myself. I have a full setup I use to coat all of my personal projects as well as for friends on the weekends. I only painted the bay with rattle can paint. It should hold up fine in for the bay.
For the wrinkle black, I've got the powder and I all I need to do is rough up the polished parts I want to do.. Saves me tons on coating. It only costs me $60 in material's to run a batch of coat versus hundred if I were to send it off to a shop.
Here is my setup and jobs I did. I've done a few dozen sets of wheels and alot of random stuff for friends. I even made my own oven
Old 11-09-16, 09:26 AM
  #1087
8052JZ
8052JZ's Avatar
I recently started to play with ceramic coatings with a HVLP gun. Still working on my process. Sometimes the coating holds up great, sometimes not so much. You can see in my previous post where the manifold below didn't hold up to well with the coating but the exhaust housing for the turbo did. I think it might having something to do with temp and cure time even though it was all done at the same time.
Old 11-09-16, 11:22 AM
  #1088
GTX580
GTX580's Avatar
Impressive skills, equipment and passion!!!
On a side note, where did you get yr oil sandwich adapter? Did you have to buy that $55 oil filter union bolt?
Old 11-09-16, 12:08 PM
  #1089
8052JZ
8052JZ's Avatar
I believe it came with the driftmotion oil cooler kit. Where in Cali are you located?
Old 11-09-16, 12:57 PM
  #1090
CatManD3W
CatManD3W's Avatar
Awesome man.......
Old 11-09-16, 06:50 PM
  #1091
GTX580
GTX580's Avatar
I am up in Sacramento. Hard to find like-minded SC people up here, maybe I need to go to more car meets.
Old 11-29-16, 08:45 AM
  #1092
Sc375
Sc375's Avatar
lol! me and 8052JZ say the same thing we been trying to hitup the local meet that happens once a month... for about 9 months now, always busy or something or another.. oh well
Old 12-08-16, 11:34 AM
  #1093
8052JZ
8052JZ's Avatar
Ant that the truth LOL
Old 12-08-16, 12:53 PM
  #1094
8052JZ
8052JZ's Avatar
Slowly been working on the car but havnt done much. I redid the battery cables and added 1g wire from the alternator to fuse box to complimant a 200amp alternator. Also ran a cable to the trunk to relocate the battery.
Also got the manifold flange resurfaced after welding on the 1" spacer. Then bolted that back onto the motor with the turbo. Also installed the cam/crank sensors. The Cam sensor needs a little bit of adjusting to get it perfectly aligned with the nub on the S3 cam. Might weld some tabs to bolt the sensor down or just fpig seal it.
Made an extention for the alternator wire that connects to the fusebox. Then Fuse box to positive battery pole that also feeds the starter.
Parts I used. The 200 amp breaker will go after the kill switch.
And the GTE cam sensor on a GE head.
Old 12-09-16, 05:19 AM
  #1095
97-SC300
97-SC300's Avatar
did you have to install a larger alternator fuse?
Quick Reply: 8052JZ's NA-T Build
