Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 05-23-16, 01:58 PM
  #1021
8052JZ
8052JZ's Avatar
Thanks guys.
The bracket is from SAAD Racing. Call them up and they will set you up.
Old 05-24-16, 09:47 PM
  #1022
Maximo018
Maximo018's Avatar
Man this has come a long way.
Old 05-27-16, 11:37 AM
  #1023
8052JZ
8052JZ's Avatar
It sure has..
On a side note, Does anyone know what the settings should be for the IGN-1a (aem high output/ proefi) coils for the AEM v2? I will be getting those finished up this weekend and need to know what the settings should be for those coils. The V2 is currently setup for the Lq9 coils.
Any help would be great thanks!
Old 06-02-16, 07:49 AM
  #1024
8052JZ
8052JZ's Avatar
Coils are finally done and in the car. Now I need to set them up in the AEM and get the it fired up.
Plug wires getting made. I could probably make 3 more sets of plug wires with all the extra wire left.
Coils mounted. Forgot to take pics of the harness but its all tucked underneath.
Old 06-02-16, 04:20 PM
  #1025
Sc375
Sc375's Avatar
now stop messing with it and lets go do hoodrat things
Old 06-03-16, 09:35 AM
  #1026
8052JZ
8052JZ's Avatar
LOL I am trying!
Anyhow she is running on the new coils after adjusting the dwell table with the help of sc375
Old 06-03-16, 02:41 PM
  #1027
gerrb
Super Moderator
gerrb's Avatar
Richard - aren't those the 105 millijoules or the high output 210 millijoules ?
Clean looking setup.
Old 06-04-16, 02:17 PM
  #1028
Sc375
Sc375's Avatar
Originally Posted by 8052JZ
LOL I am trying!
Just gotta make it to my bbq tomorrow and back home lol
Old 06-05-16, 08:35 AM
  #1029
jimmymac30
jimmymac30's Avatar
one of the cleanest engine bays I have seen! great work!
Old 06-05-16, 09:09 AM
  #1030
Sc375
Sc375's Avatar
sure is, hes put alot of time and hard work into this ive seen alot of it first hand
Old 06-06-16, 11:51 AM
  #1031
8052JZ
8052JZ's Avatar
Well trans has to come out AGAIN I really did a number on the trans testing the trans brake more then I should have causing it to over heat. 3rd gear started to whine and make some funny noising over the weekend and leaks fluid out of the vent tube during a WOT pull. Expensive rookie mistake on my part. On the other hand, coils have been setup and are working great. No hesitation or break up after 5000 through 7200rpm at 30psi.
Trans will being going back to Jakes Performance in Texas for an overlook or rebuild if needed.
And yep, didn't make it to that bbq/car festivities due to trans.
Old 06-06-16, 12:09 PM
  #1032
8052JZ
8052JZ's Avatar
They are the 105m. Unless PRoefi is making these coils with Mercury Marine, I don't see how they are getting 210millijoules out of them? Mercury Marine Pantera ign-1a. . I've searched around and there isn't any test results showing the two differences. I'm not saying Proefi is BSing on their H.O. coils but I just don't see it. Lots of 2000+hp cars are running the IGN-1a coils with great results which is why I chose these. I went with AEM because they ended up being cheaper from a freind that is a dealer for AEM. Just my thoughts.
Old 06-12-16, 08:12 AM
  #1033
jimmymac30
jimmymac30's Avatar
I just started back at post 1 and read all the way through this morning... WOW! Richard, you sir do amazing work and watching this come together has been a lot of fun to read. After long debate I decided to go NA-T as well and have slowly started putting parts together to make it happen. Watching what has happened to your car over two years gives me hope that my car too will eventually be where I want it to be. Just have to be patient. Great work my friend! my hat's off to you.
Old 06-19-16, 07:19 AM
  #1034
Coldworld
Coldworld's Avatar
great work 8052JZ I had same issues with lq9s so I know your pan great build
Old 08-12-16, 10:19 PM
  #1035
8052JZ
8052JZ's Avatar
Been MIA for a bit due to my wife having our first child . But Ive managed to get a lot done being on family leave for six weeks.
-new engine/Trans coolers installed
-Evo Brembo rear calipers installed
- Fixed all the annoying small oil leaks from fittings and what not
-Th400 went back to Jakes Performance for a rebuild along with the converter. Evertyhing was done under warranty.
Next up I am finishing up the interior with some Sparco seats, brackets and sliders which are on order with RaceQuip 5 point Harness from Real Street.
One trans and one Engine cooler. I welded -6 fittings on one of the coolers for the trans. The second trans cooler is in the passenger fender well.
[/URLName:  803CEBB0-821E-4FEA-A537-36846B859D66_zpsqeahnd66.jpg
Brand new Reman Evo 8 rear Brembo Calipers painted black with NA StopTech rotors bolted up so I can get my 15" Weld Wheels I got from Gerb.. Also replaced the brake lines to the Goodridge lines.
Front LS400 calipers are polished which I also painted gloss black to match the rears.
While I was at it I replaced the pads with some Carbotech Pads
And the trans back from Jakes. Car is back on the road and running great. Now I just need to make it to the track before something else goes wrong lol
Quick Reply: 8052JZ's NA-T Build
