Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 04-02-13, 11:46 AM
  #181
8052JZ
8052JZ's Avatar
Originally Posted by Quicksc4
Do this
move injector 1 and 2 to cylinder 3 and 4 then move injector 3 to cylinder one and 4 to cylinder #2
Try that , if you still hav ethe same issue have aem look at your box it's only $90 last time i checked and check you wiring harness.
ill give that a shot and send out the ecu if its the AEM
thanks for all the help so far on this!!
Old 04-02-13, 12:05 PM
  #182
8052JZ
8052JZ's Avatar
All the spark plugs seem to be pretty consistent and healthy and the pic of f the flooded cylinder.
Along with interior finished with all the new AEM gauges installed.
Under the radio; fuel pressure, oil pressure and water temp
Pillar pod; wideband and boost
****ty iphone pics....
Attached Thumbnails 8052JZ's NA-T Build-img_2727.jpg   8052JZ's NA-T Build-img_2728.jpg   8052JZ's NA-T Build-img_2724.jpg   8052JZ's NA-T Build-img_2723.jpg   8052JZ's NA-T Build-img_2720.jpg
Old 04-02-13, 12:56 PM
  #183
Ali SC3
Ali SC3's Avatar
Yes, if it doing it at just key on with the engine off you can and should do a test.
with key off swap 1-2 with 3-4 and then turn the key on and see if it shoots fuel into 3 and 4 instead of 1 and 2. I wouldn't try and start the car like that though.
You will have to clean alot of fuel after that so instead you could also just test the wires.
You need a voltage tester or a light and test the 2 pins on the injector connectors. positive is the black/red wire and negative is the signal wire.
If there is voltage across those 2 pins or the light stays lit all the time with the key on engine off, its the ecu or the signal wire is shorted.
Since you have 2 of them It's more likely to be the ecu, and it is rare for signal wires to get shorted.
Old 04-02-13, 01:09 PM
  #184
8052JZ
8052JZ's Avatar
Good to know! I will test the wires instead of swaping injectors sense I still have the OEM intake plunem on. All though I do need new injectors now?...
thanks for the help tip
Old 04-02-13, 05:40 PM
  #185
8052JZ
8052JZ's Avatar
Ok just did Ali's recommended test across all injectors with the ignition key at on and fuel pump unplugged, it's ready 8.5v!! So I guess the aem ems needs to be sent to aem to get fixed of it can be?!
Does that mean I also need new Injectors? Just need to clarifie so I can get started on pulling them out.
Old 04-02-13, 08:21 PM
  #186
Ali SC3
Ali SC3's Avatar
with the clips off the injector, the 2 that are bad should give you a reading when you test the voltage across the 2 pins (by sticking a probe in each pin).
the other 4 shouldn't give you any reading at all.
if thats the case then the ecu is bad, I don't think your injectors are bad.
If all 6 are giving the same reading, Im not really sure then just try swapping the clips then and seeing if it follows.
Old 04-03-13, 07:38 AM
  #187
8052JZ
8052JZ's Avatar
well I brought the ems with me to work today so I can send it out to aem to get fixed if they even can. Ill be giving them a call and see what they say.... I guess I just need to bite the bullet and get the V2
the od part is that sense all the clips are reading 8.5v I dont think all the injectors open? As far as I can see its only #1 and #2 that are stuck open. Even with 1 and 2 unpluged and fuel pump on, fuel is getting passed through the injectors into the cylinder filling it up?!
Old 04-03-13, 10:20 AM
  #188
Ali SC3
Ali SC3's Avatar
Hm, im not sure that test worked right then if all of them are reading the same. you will have to do another test cause that would make me think that its not the ecu.
If they are unplugged and still shooting fuel into the motor, then I would say your injectors are bad then.
It would seem you did loose 2 injectors at the same time. are they new or did you get them cleaned?
Old 04-03-13, 10:35 AM
  #189
99SC42
gte & na-t
99SC42's Avatar
^^^ You are correct no way it should dump fuel in the cylinder while unplugged lol , that's not an ecu problem it's more and injector problem.
Old 04-03-13, 10:46 AM
  #190
8052JZ
8052JZ's Avatar
These are new remanufactured rx7 550cc red top injectors that I got with a flow chart and all.
Shouldnt the clips not have any type or reading sense the ecu controls the ground for the injectors?
Old 04-03-13, 11:46 AM
  #191
Ali SC3
Ali SC3's Avatar
Thats what I thought, but if you don't have the injectors connected to the ecu they shouldn't be injecting fuel.
something definitely wrong with those 2 injectors if they are doing that unplugged.
the question is there also something wrong with your ems that caused it or did you just get unlucky with the injectors, hard to tell. you could always try out the oem injectors and see if there is still that issue.
sometimes reloading the cal file into the ems can help.
Old 04-03-13, 12:31 PM
  #192
8052JZ
8052JZ's Avatar
Might just be the injectors. The aem should be ok but I’ll put in the oem injectors for just 1 and 2 and see if the AEM opens them up but I highly doubt it. Now I’m currently looking at some FIC injectors.
Have one other question. I'm wondering if getting 900cc or 1100cc injectors would be ok for this mild setup and not cause any issues. The reason I’m thinking to go that route is because I have another motor that is completely built and when the time comes to swap them over I don’t have to get new injectors again. If those or too big for this setup than I will have to go with their 650cc injectors. I much rather get the bigger CC injectors so I don’t have to get another set when swapping the built motor over.. Hope that makes sense
Old 04-03-13, 12:50 PM
  #193
99SC42
gte & na-t
99SC42's Avatar
You can go as big as 2150cc you will be fine if your on EMS!
FUZION (08-22-21)
Old 04-03-13, 02:38 PM
  #194
8052JZ
8052JZ's Avatar
well alright than.. FIC 1100cc injectors that HIPSI had for sale are on the way
Old 04-03-13, 02:59 PM
  #195
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
This is just another reason why I check the forums daily. The knowledge of people is out there. Lets hope the new injectors fixes the problem. BTW, the two gauge pod holder looks good, even though I like the three better. LOL
Quick Reply: 8052JZ's NA-T Build
