Build Threads Details on Club Lexus SC owner vehicles
My SC300 NA-T Build
Old 05-11-13, 06:00 PM
  #46
lilSCsteve
lilSCsteve's Avatar
Glad to see you're bringing her back, I'm still trippin over that previous hack job! Wow!
steve
Old 05-11-13, 08:10 PM
  #47
BAD954BOI
BAD954BOI's Avatar
Looking forward to the progress
Old 05-17-13, 12:19 PM
  #48
marshall2j
marshall2j's Avatar
Thanks guys. Hopefully have it running by this weekend. I have securely mounted the oil cooler, and will hopefully mount the PS cooler by tonight. Tomorrow I will be getting the new tires mounted to the wheels as well as re-mounting the FMIC, routing the PS and oil cooler lines, bleeding the fluids (PS, brakes), adding new fluids (MT90, RL Heavy Duty Shock Proof, Oil). Hopefully mounting the bumper back on Sunday morning and driving around tuning and diagnosing Sunday afternoon. I should be posting pics, but killed my Android a couple weeks ago. Pre-ordered the S4 coming in a week or so... WOOT!
My buddies are gonna be building me a custom single exist exhaust and a battery box for the trunk in June.
Jeremy
Old 05-17-13, 12:33 PM
  #49
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I am looking forward to the progress.
Old 05-20-13, 12:27 PM
  #50
marshall2j
marshall2j's Avatar
Didn't get it done because life happened....
Anyways, completed brake fluid change/bleed, power steering cooler hooked up 100% and mounted, axles hooked torqued, diff fluid switched.
Almost there....
Old 07-08-13, 07:23 AM
  #51
marshall2j
marshall2j's Avatar
Car is now running! and moving around. Still need my buddy to build me a new exhaust. I think I may have a rear main seal leak though. I see a few drops coming out where the bellhousing meets the engine.... dropping a tranny with jackstands? ugh idk lol
I had to fix an oil leak from my sandwich plate adapter and relocate the oil cooler because it got in the way of the IC pipes. In the middle of switching seats to a Corbeau A4 (mostly the buckle now)... from 70lbs to 36lbs! 34lb reduction in just the driver seat alone! Once I get my new single can exhaust, I hope to save more.
EDIT: Oh yeah, I also found an O2 sensor underneath my driver's seat that appears to be hooked up to the car somehow...
Old 05-23-14, 06:36 AM
  #52
marshall2j
marshall2j's Avatar
Haven't posted in a while but fixed 95% of all my electrical issues over the winter and the car is almost ready to see track duties. Only things not fixed are the length of some of the wires.... could be cleaned up a little more, but functionally works great. My weird issue where I was blowing out taillight fuses everytime I turn on the headlights is gone!
Also completed the following over the winter:
-valve cover gaskets
-new optima "red" battery mounted securely in trunk
-New pcv
-remounted intercooler
-began serious paint restoration (lots of work but shine is coming back! )
-removed wing and repainted the trunk (not my best work, fixing body work sucks)
-secured everything in engine bay
-started fixing the tune of the car (is it just me or does AEM v1 "forget" the tunes)
My car is running beautifully and I have basically been dailying it for several weeks. So far no hiccups... knock on wood...
Old 05-23-14, 07:36 AM
  #53
BoostinSc3
BoostinSc3's Avatar
i def had the saem problems on my 93 sc300
Old 05-23-14, 09:01 AM
  #54
marshall2j
marshall2j's Avatar
Also I forgot to add:
Installed Supra TT sway bars
Installed tein circuit spec type re coilovers (for supra tt)
Car is handling very nicely, but still doesn't feel as "sporty" as my Supra despite having "racing" spec coils
vugoodoll
Build Threads
55
03-26-13 08:02 AM
Todd1225
Performance & Maintenance
22
05-12-05 03:50 PM
Derf
SC- 1st Gen (1992-2000)
02-17-05 03:33 PM
cds01
09-23-03 04:13 AM
kmn5
06-25-01 03:19 PM
Quick Reply: My SC300 NA-T Build
