Build Threads Details on Club Lexus SC owner vehicles
DoomLight's 1992 SC300 1JZ Swap & Build Thread
Old 05-22-12, 08:03 PM
  #46
joe diego
joe diego's Avatar
This is huge. Awesome stuff man! You're going to have so much fun once you hit the rode. I thought about selling my Sc 1j but after reading threads like yours I changed my mind, and plus no one wanted to buy it. Ha.
Old 05-23-12, 07:52 AM
  #47
DoomLight
DoomLight's Avatar
i been looking for wheels like crazy. i seen a few guys on here with the TSW Snetterton wheels and i just had to have them. TSW was on back order for new ones so i began trolling craigslist till i found a set. 650 for a set!
these came in +20 offset. so they were pretty flush. 5x114.3 19x8 front and 19x9.5 rear staggard.
did some tire research and got some 235/35/19 for the front. the rears were tricky... i started wth 285/35/19 too wide! lol my car SAT on the tires. after i dropped it. no good at all.
this is a shot from the door jamb. u can see how much it stuck out.
here is a shot of me swappin the wheels. from 15inch pizza cutters to 19inch steamrollers
Old 05-23-12, 07:58 AM
  #48
DoomLight
DoomLight's Avatar
ok i slacked off enough.
here is some pics of me installing lowering springs. this will work for now till i get coil overs 125 Versus 700. its a simple conclusion.
fresh out the box.
spring height comparison.
then installed on one strut.
car was almost slammed lol
i used a block of wood to gauge the distance. looked like more than 2 inches.
the backs were crazy low. i used Supra mk4 lowering springs. by the way.
sorry for the lousy contrast. cell phone cameras go bonkers
Old 05-23-12, 08:23 AM
  #49
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Man the drop looks great for just springs. No more donka donk 4x4 status.
Old 05-23-12, 08:39 AM
  #50
DoomLight
DoomLight's Avatar
moving along. i realized my radiator was crap! it was old with 170k on it. so naturally i ordered up an aftermarket all aluminum radiator. i've read that for some reason these 1jz and 2jz GTE motors generate much more heat than the GE/Non turbo iterations. so i figured. a larger radiator was in order.
i ordered one with electric fans and shroud combo.
all bolted together.
so next i proceeded to remove the useless old one.
and its out. by the way u can see the big 50mm Greddy blow off valve I put on.
here is a few install pics.
i have the fans hooked up to a relay and a honda fan switch that kicks the fans on at 170 degree's automatically. soon an AEM will control them. but for now this will have to do.
Old 05-23-12, 08:52 AM
  #51
DoomLight
DoomLight's Avatar
after a month. i located a SC400 diff for 60 bux. i put that in. because it matched the gears in the r154. the stock automatic diff was ridiculously short. it made the engine rev like a 1.6 liter 4 cylinder.
so here are a few diff change pics.
pulled up onto lift. and racked it up.
up in the air. time to snap a few underbody pics.
accessible wastegate access! not as easy as you think tho.
low mounted intercooler. i didnt have much room to work with. its tilted forward. and i am working making a skid plate to protect it.
unhooked mufflers and piping.
got the sucker out!
before i put it in. (no pics taken of this) i had to swap out the flange for the driveshaft. apparently there was a change. so if u do this. you need an odd ball socket. 35mm to be precise. get that.
here is a pic of the Diff before i put it in.
mission complete. no pics of it completed. its just a diff lol
File Type: jpg
Old 05-23-12, 08:56 AM
  #52
DoomLight
DoomLight's Avatar
next batch of pics will be about the body shop.
Old 05-23-12, 09:01 PM
  #53
One HoT
One HoT's Avatar
I'm liking this build! Where did you purchase the aluminum radiator and fan combo? Looks very nice, polished and all!
Old 05-23-12, 09:16 PM
  #54
DoomLight
DoomLight's Avatar
i got it from ebay, but dont tell anyone lol i might get hated on. lol actually its a good radiator. no problems with it so far. it could fit a little better on the bottom mounting points. but other than that. its works and the extra coolant capacity is welcomed.
Old 05-23-12, 10:03 PM
  #55
pieisgude
pieisgude's Avatar
Nice work! Can't wait to see it all the same color.
Old 05-29-12, 12:46 AM
  #56
1WILLY1
1WILLY1's Avatar
This is a really cool build.
You are a mechanic by trade I assume right?
Old 05-29-12, 06:27 AM
  #57
DoomLight
DoomLight's Avatar
Yessir, I will update it later today. Been slacking
Old 05-30-12, 09:03 PM
  #58
biturbo632
biturbo632's Avatar
man that's a great build!! You're doing a lot of things in a short time! I like!!! Subscribe!
Old 06-05-12, 08:20 AM
  #59
DoomLight
DoomLight's Avatar
time to get this baby apart and to the body shop for paint and dent removal. here are some of the pics in order from apart to being together again.
stripping it down, taking off wheels, bumpers, everything i could remove.
Old 06-05-12, 08:23 AM
  #60
DoomLight
DoomLight's Avatar
these pics are about a week into the shop sanding the parts down and primering everything. also removing dings and dents.
Quick Reply: DoomLight's 1992 SC300 1JZ Swap & Build Thread
