Build Threads Details on Club Lexus SC owner vehicles
another 1jz big single build
Old 05-03-12, 07:23 PM
mrae101
mrae101's Avatar
Default another 1jz big single build
Okay i know every one has seen it before and with better parts but im going to put up my pic any way
My car is a royal jade pearl 92 sc400 with a 1jz swap i decide i wanted to do a budget minded big single build so here it is
I started buy riping the old turbos off which sucks also decided to re do the coil wiring
you can see my megan motor mounts still holding up well
alright now it's time for the parts
THE TURBO
It's a godspeed project t67 70 ar. with the anti surge shroud. Now before any one says good luck with that turbo I went the best possible route for this i bought it direct from gsp you pay more but it come's with waranty. It's not high tech but it works
now the manifold also a cheap one obx that says it all. they wont work for you out the box i have a good welder and reinforced it as well as change the wastegate pipe.
here it is as it came
you also need oil lines and proper fittings
For the down pipe just go too driftmotion you won't go wrong
Fits up well
O2 for my bung hole
Now i've got to tune it so i went with Greddy emanage ultimate got it for $400.00 with a s2k harness. any one need the harness Just change the pins and where golden
Went straight to thrust for the harness
And installed
Now at this time i got a new raidiator as well and installed a new transcooler
Now i dont have install pic but it was staright foward if you can't figure out how to put this all together by now you should be having a mechanic do yours
This is a pic of me testing everything
Old 05-03-12, 07:52 PM
mrae101
mrae101's Avatar
In this pic here you get ow every thing will lay out im sure a few hate my piping that okay i'm fine with it
You can see how my wastegate has been moved don't worry it's close but doesnt hit
I then tighten every thing down checked for leaks and did my first start up
here video
http://www.facebook.com/media/set/?s...type=2&theater
It had to be driven to a friends house i have no power in my garage and i have no laptop
I took this one of every one standing around it and just so youknow i drove it hood less and open dp We also took the time to make sure the coils where all working right
Old 05-03-12, 08:08 PM
lilSCsteve
lilSCsteve's Avatar
You're off to a great start with the 1JZ...looks good! On a side note, I would be worried about the ICP coupler getting too hot against those valve covers tho? Overall good job! Thx for sharing...
Steve
Old 05-03-12, 08:09 PM
SFrymyah
SFrymyah's Avatar
I bet the hood doesn't close with that wacky pipe routing. why didn't you just clock the turbo down and space it up?
Old 05-03-12, 08:23 PM
Trevstuh
Trevstuh's Avatar
I was going to ask that question.
Old 05-03-12, 08:29 PM
mrae101
mrae101's Avatar
The hood does close just fine i'm much further than this ill post more pic in a while
Old 05-03-12, 09:40 PM
mrae101
mrae101's Avatar
more photo's
And there it is right now im taking it back apart and am going to install titanium wrap on every thing I also have a ton more parts to install yet
Old 05-03-12, 09:41 PM
mrae101
mrae101's Avatar
I also have tire's on the way cause it is plan ugly like this sleeper mode
Old 05-03-12, 11:02 PM
DoomLight
DoomLight's Avatar
never seen anyone route pipe that way. you should of used that coupler the other way and rotated the turbo downwards.
interesting to see how this is completed.
Old 05-04-12, 06:21 AM
vr6-t
vr6-t's Avatar
Got to clock that turbo and modify your hot side piping!
Old 05-04-12, 06:22 AM
kez
kez's Avatar
Looks good piping is a lil different
Old 05-04-12, 06:23 AM
kez
kez's Avatar
Where is you fan or fans at?
Old 05-04-12, 06:41 AM
99SC42
gte & na-t
99SC42's Avatar
He is running (2) electric fans
Nice setup OP
Old 05-04-12, 09:52 AM
93MSB
93MSB's Avatar
this.
you will kill that turbo pretty quickly with the oil lines clocked sideways like that. you need to have them straight up and down
otherwise looks pretty good
Old 05-04-12, 02:38 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
You made it look so simple and done in a few hours. Its better than my 9 month old build.. :-)
Quick Reply: another 1jz big single build
