Build Threads Details on Club Lexus SC owner vehicles
2jzGTE SCs - The Siblings of my Supra MKIV Toys
Old 03-30-12, 06:26 AM
  #196
gerrb
Super Moderator
gerrb's Avatar
Originally Posted by PoGikoSc4
Danngg Mang Gerry u had done a lot since i left ur home this morning lol and that TRD Exhuast is a monster in person lol..thanks again for all the help bro..
no problem anytime !
Old 03-30-12, 08:25 AM
  #197
gerrb
Super Moderator
gerrb's Avatar
Uh Oh ..
Decided to mess around with the differential I got from a swap with one of my V160 getrag. I said, let me change the oil though the guy said he didnt have it for long and looks like it is new so oil was probably new. But I wanted to make sure and went ahead... to my surprise no oil inside the pumpkin. That made me worry .. hope this pumpkin didnt have an open diff .. pumpkin literally looks brand new .. so I decided to open the pumpkin and verify.
YEHEY .. TO MY SURPRISE .. it is realy a damn brand spanking new TT LSD differential .. no traces of oil had been poured into this LSD Differential ... hhhmmm.. I will probably just sell this since it is brand new .. these cost almost $2k and just use my old TT LSD diff laying around...my friend didn't even probably know that he got a brand new TT LSD differential. He will be surprised .YESSSSSHHHHHHHHH !
Old 03-30-12, 11:11 AM
  #198
NaturalJZ
NaturalJZ's Avatar
I love your body work, I'm going to be trying to fix the same kinda things, dings and nicks, this summer. wish you were local, could learn so much haha.. Those small like hail dings, do u pull them out? if so with what tool? or do you just bondo it smooth?
Originally Posted by gerrb
The W58 5 speed tranny can't hold much power .. it will more likely break before you can break your current open diff on your SC300. if you are making over 450rwhp that W58 wont last long... .if you dont want the expense of the 6 speed v160 getrag tranny , then go for an R154. For the differential, using the supra 5 speed diff pumpkin with 4.083 gear ratio and installing a TRD LSD will be a good strong rearend.
I am not sure what the gear ratio of your current SC300 5 speed differential, though I believe it will be almost similar to that of the supra mkiv 5 speed since they have same drivetrain (engine/transmission). If that is the case , installing a trd lsd on that pumpkin should work.
So supra mk3 or 4 pumpkin is what should search for?
Old 03-30-12, 01:30 PM
  #199
gerrb
Super Moderator
gerrb's Avatar
If they are big enough where you can drill a small hole and screw in the puller .. you can pull them... others just body filler . If you check the picture of tools I posted , the one with a screw at the end, a triangle shape handle on the other and a barrel (drum shape) handle at the center is the puller.
I was referring to the MKIV & SC300 5 speed pumpkin .
Old 03-31-12, 07:33 AM
  #200
gerrb
Super Moderator
gerrb's Avatar
Stock JDM Supra 2jzgte engine will be installed initially before any of the upgrades.. just to get the car running and not complicate matters. These are USDM supra 2jzgte cams which I will throw in since they are just laying around my garage before I go to a more aggressive cams eventually .
Old 03-31-12, 08:01 AM
  #201
gerrb
Super Moderator
gerrb's Avatar
JDM Supra MKIV 2jzgte engine going inside this SC400... engine still has the 6 speed flywheel/clutch/pressure plate but would be taken out since I am going with a built Boost Logic Auto Transmission on this car. On the other Lexus SC400 I will do a 6 speed swap.
Old 03-31-12, 09:15 AM
  #202
gerrb
Super Moderator
gerrb's Avatar
For those asking about the Supra MKIV 93-96 and 97+ mounting brackets and mounts.. here they are for your info.
These are the 97+ mounting brackets and mounts
97+ mounting bracket are longer than the older ones
97+ mount is shorter than the older one
93-96 mounting bracket just like on my pre 97 supras are shorter than the newer one
93-96 mounts just like my pre 97 supras are longer than the newer one.
NOTE : If you want to use the TRD mounts , you will need the 93-96 mounting brackets since those trd mounst have same size as the older mounts., they wont work on 97+ brackets.
Old 03-31-12, 01:49 PM
  #203
gerrb
Super Moderator
gerrb's Avatar
I am trying to reuse parts that originally were on this car so I can save a bit while am running on the stock setup. So I figure I will reuse the original SC400 radiator and relocate its overflow tank since I am using a MKIV or SC300 fan shroud. In the future when I have the aftermarket twins or single turbo and higher boost , then I will spend on the cooling system.
Old 03-31-12, 01:53 PM
  #204
gerrb
Super Moderator
gerrb's Avatar
Today , removed more fluid piping connections and bolts so that engine will get out easilly
Old 03-31-12, 01:58 PM
  #205
gerrb
Super Moderator
gerrb's Avatar
Compressor / Air-conditioning pipes should be disconnected
Old 03-31-12, 02:03 PM
  #206
gerrb
Super Moderator
gerrb's Avatar
Engine Harness connectors on the engine bay should be disconnected / unplugged / unfastened.
Igniter connections
and moredisconnection and unfastening ....
Old 03-31-12, 02:05 PM
  #207
gerrb
Super Moderator
gerrb's Avatar
Once you are done disconnectiong / unbolting stuff in the engine bay ... go to the passenger front floor board to take out the computer connections ...
Old 03-31-12, 02:06 PM
  #208
gerrb
Super Moderator
gerrb's Avatar
  #209
gerrb
Super Moderator
gerrb's Avatar
Old 03-31-12, 02:07 PM
  #210
gerrb
Super Moderator
gerrb's Avatar
Quick Reply: 2jzGTE SCs - The Siblings of my Supra MKIV Toys
