Build Threads Details on Club Lexus SC owner vehicles
new member and my Manual SC400 build/what should i do thread !!
Old 02-18-12, 11:19 AM
trexm3
trexm3's Avatar
Default new member and my Manual SC400 build/what should i do thread !!
hey guys so i picked up this sc400 a while back and have been contemplating moving on to something else, or make it 100% track ready, heres the rundown of everything im sure you guys have seen it before
.. please understand i bought it this way all i did was roll the fenders and paint the cage so far ..
so not looking for negative comments .. some of you probably know me from zilvia and other forums have done everything from s13's to aa stage 2 meth injected e46 m3 lol anyway hope to learn a great amount here
1992 SC400 with 112k original miles Black on Tan. 1UZ-FE (V8)
Supra R154 trans had 78k miles when pulled from the car "I just replaced the last one due to a few bad synchros.
POWAAA
S-AFC (tuned)
Custom equal volume long extractor headers (Rush AU)
Carsound cats, x-pipe, flowmaster mufflers
Walbro 255LPH high pressure fuel pump
1.5 way LSD from 94Supra N/A with 4.27 gearing
Custom one-piece driveshaft
SUSPENSION ISSHHH
8-point full roll cage
Daizen Front Control arm bushings
Daizen Rear Control arm bushings
Daizen Front and Rear Sway bars
Daizen front and rear sway bar bushings
TEIN HA coilover system
Daizen rear camber control kit
LOOKERS
Just got it out of the body shop, the car has zero dings or scratches.
door cards
Origin front bumper
Origin rear bumper
Vertex rear spoiler(i removed it but still have it)
HID low and highbeams
V-speed side skirts
Painted Carbon Fiber Hood with hood pins
GUTSSS
Cage ( just painted it)
98 Supra TT front leather seats
Clarion 2din CD/MD player
"have single din setup,waiting for some time to put it in"
Custom Laser blue dash needles(by lextech lighting).
Nakamichi factory system
replaced climate control lights with 97+ scheme
optional cupholder added
ROLLIN N STOPINN
I-forged 19x8.5F 19x10R "need to be refinished or powdercoated"
Tires = 245/35/19F 275/30/19R
Supra TT front brake upgrade with cross drilled rotors (Brand new)
Lexus SC brakes rear (Brand New)
Goodridge SS brake lines (all four corners)
EXTRA
A/C system converted to R134 from R12
New Supra spare
mmm NEW STUFFF
CRD custom bellhousing
CRD custom flywheel
CRD custom ring gear
Exedy Clutch
Exedy pressure plate
Spigot Bush (this is from a turbo MKIII)
Throw Out bearing (this is from a turbo MKIII)
slave cylinder & push rod (this is from a turbo MKIII)
Slave cylinder and bolts (this is from a turbo MKIII)
release bearing (this is from a turbo MKIII)
pivot ball (this is from a turbo MKIII)
(6) M12 x 1.25P x 50 long original
Toyota
bolts -bellhousing to motor (OEM)
CRD supplied (3) M10 x 1.25P x 45 long original Toyotal Bolts - Bellhousing to motor (OEM)
CRD MKIII turbo slave cylinder (this is from a turbo MKIII)
*R154 transmission from soarer
TT
(this can be from a turbo MKIII)
*MKIV soarer TT tailshaft (this is from a late model MKIV
pilot bearing (from a turbo MKIII)
Flywheel flex plate bolts (8) M10 x 1.25 pitch x 26 long High Tensile Bolts. (OEM)
SC300 clutch pedal 58804-24030-03
SC300 clutch pedal box sub assembly 47101-24060
SC300 brake pedal
SC300 brake pedal box sub assembly 31301-24050
SC300 clutch pedal pad 31321-14020
SC300 brake pedal pad 31321-14020
SC300 shifter boot
SC300 shift ****
SC300 shifter trim bezel (specify with or without heated seat)
supra 6speed master cylinder 31410-14310
SC300 hardline for master cyl
MKIII turbo hardline for slave cyl
bads- needs a extremely good interior detail
** car currently is on a winter 350z setup and might be having the iforged refinished**
**yes i have the other seat i keep it out when im transporting tires**
maybe ill get some pro pics taken soon so you can see more then the crappy phone pics
how it sits currently
Old 02-18-12, 11:38 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
I'd probably skip the purple wheels, but aside of that drive the dang wheels off of it! It was built to get down.
Old 02-18-12, 11:58 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I second that... what he said ^^^^^^
Old 02-18-12, 11:59 AM
Kira X
美少女戦士セーラームーン
Forum Moderator
Kira X's Avatar
That's a really nice SC!
Old 02-18-12, 12:26 PM
LunaVyohr
LunaVyohr's Avatar
I believe this was on the CL classifieds a few months ago. Soooo glad to see more manual 1UZ SCs popping up.
Old 02-18-12, 12:51 PM
trexm3
trexm3's Avatar
thanks guys yea the 350z wheels are my track set/winter beaters ... probably going to paint them white .. im looking for a little more power out of the 1uz though.. if i keep it ill be getting down with it this season and probably go with track seats partially gut it , some power addders , weld the diff possibly get something to get a better angle maybe modify knuckles... its a weekend / fun car so i barley drive it maybe twice a month lol
right now i working on getting the slave cylinder fixed and i think i was the guy who had it listed on c list i bounce back and forth between keeping it and selling it..
if i start adding more ill make this my build thread .. think im going to go order a soarer hub for my jdm wheel these stock wheels are ugly haha
Old 02-18-12, 01:10 PM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
Not really seeing the point of those rear seats at this moment, LOL. Toss'em
Old 02-18-12, 02:46 PM
trexm3
trexm3's Avatar
agreed once i figure out if im keeping it for sure ill be parting all the stock interior pieces most likely!!
this might turn into a build thread one day haha
Old 02-18-12, 03:23 PM
Luv2xl
Luv2xl's Avatar
new the original owner and the shop who did the r154 swap. Some quality parts (at the time) were used to get this V8 to mate with a 5spd. The car looks better since the PO, did neglect it due to lifes adjustments.
Keep it and run it hard. The V8's can be had for cheap. Throw some juice at it and see what it can do, while you blueprint a built V8..
Old 02-18-12, 05:35 PM
trexm3
trexm3's Avatar
thanks man will do.. just been researching the forums and other sites , contemplating turbo - sc - or itbs .. also do you think upgrading to the vvti 1uz from 92-96 1uz would be worth it? Also what basic 1uz upgrades would you recommend me starting with?
thanks again for the input
Old 02-18-12, 05:45 PM
shivan0124
shivan0124's Avatar
very nice car, and nice wheels but the color i would have to get used to
Old 02-18-12, 07:05 PM
LunaVyohr
LunaVyohr's Avatar
Swapping in the VVT-i 1UZ is a very complex, time consuming swap. The money and time you spend on that swap could be better spend on upgrading your current motor. Also, the VVT-i will throw a check engine light if you try to keep it manual. Overall, to me, not really worth it.
As for making power with 1UZ, they respond well to basic bolt-ons - BFI upgrade (Big ****ing intake), exhaust, headers, etc. Beyond that, you'll want to go standalone, and you'll want to invest in having the motor retuned if you haven't already - 1UZs run notoriously rich from the factory.
After that, to make serious power with the V8, you're looking at spending a pretty penny on a custom turbo/super charger/ITB set-up. Go to Lextreme. It's a website dedicated to the Toyota V8. There's a ton of Australians on their forums, as Australia adores the 1UZ, and has much more support and aftermarket options for it than we do in the states.
Old 02-18-12, 08:36 PM
trexm3
trexm3's Avatar
gotcha haven,t ever done a itb setup before so im leaning towards there more , just run some clean filter/screen on them
Old 02-18-12, 08:37 PM
Axmily
Axmily's Avatar
DAMN! That thing is sick! are those Ebay Headlights? they look really good on the black. i also will be swapping my car to manual very soon aswell!
Old 02-19-12, 05:18 PM
trexm3
trexm3's Avatar
honestly im not completely sure , i didn't purchase them they came on the car but searching around id guess 98% that they are the ebay ones
Quick Reply: new member and my Manual SC400 build/what should i do thread !!
