"Biturbo 2JZ swapped' Soarer Build Thread"
#151
I think I'm still having problems with uploading pictures as I can see them on my computer but not on my Ipad. I guest no one's comments may be cause by unshowing pictures?
#156
Did you do anything special to get the rideskinz rear lip to install so nicely? I've seen another person have issues getting it flush around the license plate area, and I've held mine up temporarily and I think I'm going to have the same issue. Yours looks perfect around the license plate, how'd you do it?
#157
When the windsheild guy remove my quarters glasses he actually cutted all the metal bolts that was on both glasses (you know when you remove the trim Inside you got 4 bolts on each glass...)
Seeing them on the floor I flashed and flatten them a little bit a glued them to the lip.
It. hold. perfectly. So basically, my lip is "simply" bolt on the car.
I'm searching 2 or 4 mores for the sides right know. Two way tape just it's an option!
#158
Gotcha, so you more or less just glued a threaded stud to the lip, drilled a hole in the bumper that you put the stud through and tightened it up with a nut? I was actually considering riveting it or something because it does seem like the lip has to be mechanically attached, not just adhered with tape. But maybe will have to consider that. Do you have any pics? Thanks for the insight though, appreciate it!
#159
#165
Ok guys.. I need help!
I'm having some horrible front inner tire wear. I have to stich them from side to side at like 5-6000 kms! My car is dropped and I drove I a lot during summer (10000km or more) and it's stored during winter. So it does cost me a lot on tire. I'm doing to raise the front a littlllee bit but I don't want to raise it to much as it would be ulgy to me. I've got my car aligned and it does have around 1.5 degrees of camber in the front.
At the point I am, the only way I think I can help my car with my front tire wear is with less bump steer. For example, the rear as approximatively the same camber setup as front, but tire last longer!
I've seen other member way much more dropped than me on CL and I've search for CL member that installed aftermarket Tie Rods like megan racing or Battle Version.
Does it Worth it? I seem like I can "drop" the tie rod end turning point on the knuckle like only half an inch! Is that enough?
