HiPSI's NA-T / Build Thread - Billet 6265 in store
#121
That step bit should work fine, remember to clean and grease at every step. you may need to start with the smaller one first, then swap out after 1/4" or so.
You can use a threaded 1/2 npt nipple pipe (male on both ends basically) maybe an inch or 2 longer than the NPT side of your current fitting (about 3"-4" total), then a female to female coupler to your existing fitting, or you can try and find another adapter that is -10an to a female 1/2 NPT if that even exists.
assemble the fittings together with thread sealant and tighten, then install all together at once.
#123
Thank you man I procrastinated long enough!
I'm pumped to get it tuned and be able to rip on it. I need to finish the midpipe section to reduce down to the tsudo catback and then get a semi decent small psi tune on it.
GTE covers would make it look 10x better but the na covers work and are free! Plus the oil feed fit perfectly through the timing cover. Got any gte covers you want to donate ? Aren't they like 200-250 usually?
#133
Sheesh that right there is CLEAN I got to stop playing and install the shid sitting in my garage.. That ffim is killing me cause I know it's not nessasary I could spend that just about 2k investment on something else but it makes the bay so much cleaner.. Smh
#whats next ?
#whats next ?
#134
#whats next ?
#whats next ?
Next is finishing the midpipe install. Then most likely a cheap inexpensive w58 clutch to hold. Install the fuel mods that I have and then crank it up further.
