Build Threads Details on Club Lexus SC owner vehicles
HiPSI's NA-T / Build Thread - Billet 6265 in store
Old 12-27-11, 08:34 PM
  #106
MIKU*SC3
MIKU*SC3's Avatar
Im liking the FFIM!!
Old 12-28-11, 03:38 AM
  #107
SOLID300
SOLID300's Avatar
Originally Posted by HiPSI
The .82 open inlet turbine is comparable in size to the 1.00 divided due to the center of the turbine housing being metal and taking up space. My manifold was divided so I figured a divided turbine made sense.
Ok I can get that. One great thing about divided though is that you can throw in a quick spool valve in the future if you want.
Old 01-01-12, 04:45 PM
  #108
Dan@FSM
Dan@FSM's Avatar
Originally Posted by Ali SC3
Exactly what i was getting at, if you don't plumb it back into the intercooler piping, you will have a giant boost leak without a check valve of some sort.
The TT IACV flange has a recessed lip for a check valve so you can run an open filter.
We designed our FFIM idle control flange to seal under light load or wide open throttle/positive boost pressure condition's. The only reason there would be a boost leak is if the IACV is bad or setup improperly through the EMS. The only reason to plumb it back in would be to quiet it up some.
Dan@FSMoto
Old 01-02-12, 07:00 AM
  #109
HiPSI
HiPSI's Avatar
Dan@FSMoto
I recirculated it to get rid of the sound, it was pretty obnoxious the car sounded like a train whistle. Is there any other way to remedy this? I can still hear it with the line recirced back to the intake path, it's only slightly audible. While cruising the whistle goes away under light throttle and full throttle which I'm assuming is the IACV closing.
Old 01-02-12, 08:23 AM
  #110
drifter x
drifter x's Avatar
this looking i plan on NA-T soon keep the pics comming!
Old 01-02-12, 08:35 PM
  #111
JZBrian
JZBrian's Avatar
just went threw the whole thread and I must say that's a really nice NA-T set up.Super clean and done right.I love the distributor-less set up.I never saw that done before
Old 01-03-12, 11:40 PM
  #112
lookEVO
lookEVO's Avatar
Looks good bro.
Old 01-11-12, 08:51 PM
  #113
98$c300
98$c300's Avatar
Nice build!!!!
Old 01-12-12, 10:03 AM
  #114
cheddarSC4
cheddarSC4's Avatar
sick build!! love the forward plenum
so i take it you cant use a TT intake on the na head?
Old 01-12-12, 10:39 AM
  #115
HiPSI
HiPSI's Avatar
If you drill and tap properly, aluminum seals very well. That spot on the pan is thick enough.
You can always do one way and switch to the other, both will work.
Hey Ali,
I went ahead and purchased a 1/2 NPT to 10an aluminum fitting for the oil pan. The drill size that 1/2 NPT calls for is 23/32 or alternate size is 3/4. I bought a Irwin 4 unibit combo from Lowes and I'm assuming I can use the one that opens up to 3/4"? And then tap it with the 1/2" NPT? Or should I open it up with a smaller step bit, and then finish the hole with a 23/32 drilled bit? I'd like to just use the unibit to keep as little shavings from entering the oil pan as possible.
What I bought from Lowes:
http://www.amazon.com/Irwin-Industri.../dp/B0000EI9AK
Also what did you use to seal the thread to the oil pan? Teflon tape? Red RTV? Loctight to keep it from back threading like people use on the valve cover 10an fittings? Or I've read that using the Toyota gasket making glue is really good as well, Toyota FIPG.
Old 01-12-12, 10:41 AM
  #116
HiPSI
HiPSI's Avatar
No sir that would be way to easy!
Old 01-12-12, 10:42 AM
  #117
stockhatch
stockhatch's Avatar
I use black FIPG for that kind of thing, and have not seen any leaks yet.
Old 01-16-12, 07:48 PM
  #118
BAD954BOI
BAD954BOI's Avatar
Lets get a pic of how much room you cleared up with that cop conversion
Old 01-16-12, 08:59 PM
  #119
HiPSI
HiPSI's Avatar
Just realized I don't have a good "after" picture showing that. The amount of space it free's up is ridiculous. I'll have to snap a shot like this but how it currently looks tomorrow for reference. You could seriously clear a gt42r or Borg Warner with ease.
Before:
After:
Old 01-17-12, 09:09 AM
  #120
HiPSI
HiPSI's Avatar
Is this 1/2" NPT going to work? From the looks of the default semi hole stamped into the stock GE oil pan, the 1/2" NPT fitting is only going to thread in maybe a 1/4 of an inch max from the initial depth of the hole. My intention is to drill out the hole using a 23/32 drill bit and then tap with a 1/2" NPT for this fitting and then seal it with Toyota FIPG but I'm afraid there won't be enough room to thread the fitting in due to the depth the hole has already.
Showing the amount of threads on the 1/2" NPT side before setting it in the hole:
Showing the amount of threads holding the fitting inside the hole against the inside wall where it will start to thread in:
Any thoughts? Will it be enough to seal and hold with that little bit threaded in? I do have the flange too just in case.
Quick Reply: HiPSI's NA-T / Build Thread - Billet 6265 in store
