SC570--The OFFICIAL build thread
#513
But I now have 102mm of throttle body inlet, and the throttle response is outstanding. No test drive yet, and the PCM is still learning the basics to get the idle to calm down a bit, but starting to hold steady at 850-900 rpm. So before anything cosmetic, needs the 100mm MAF housing, and a dyno session.
I went with the Nick Williams 102mm over the Fast cause of the reviews and it came in black. Only pic as of tonight:
#514
Got to take the SC570 out for a spin yesterday evening with the new CCW reps. Traction from a roll is nonexistent with the 275's in the back, even feathering the throttle 1st-3rd is tricky, but does some great 3rd gear rolling burnouts. Once on the freeway, the 102mm intake and throttle body really came alive with the cam. And finally got the chance to have a good line up and put a 5.0 Coyote in his place from a roll.
Trying to get some time to get some pictures today of the new daily setup. Should be ordering the lsd, new gears and a 28" drag tire set up soon, and a new GoPro to get some footage.
#515
Couldnt get a full picture of the car, my kids are asleep so cant start it to pull it out of the garage. Might pick up some fiberglass and try finishing the hood again one of these days. But for now, and until I get a new Gopro or other small camera for video, these will have to do:
#519
Finally a worth while update.
Ordered my 243 heads, just over 40k miles on them from an '06 CTSV. This should bring compression up to around the 11:1 area with the new headgaskets, and with the cam, intake, exhaust, and a good tune yield around 450+/- rwhp.
#520
Huge thumbs up for this build. I've recently picked up a 94 sc300 shell and plan to put an LSX in it as well for a drift car for next season if I can get it ready in time. Any advice on finding motor mounts or is Mike at AMS the only guy that makes them?
#521
Only other option I can think of for mounts is using a motor plate and mid plate. I have been considering swapping, but my car is fairly straight line specific. Not sure how motor/mid plates would work for a drift setup, but it is a nice very solid option.
#522
Thanks, be sure to post up a build. As for the mounts, Mike is the only one that makes them, if he still does..Im not sure. I know there are a pair in the classifieds, drop a line to sc300bigtx, he has them.
Also, I plan on posting up the build. It should be a fun ride
#523
Got confirmation today that my 06 CTSV 243 head are on their way, so major bump in compression coming. And got my 100mm maf in the mail today while I was at work. Time to get the new headgaskets, studs and possibly new pushrods ordered, then get it to a dyno. Now time to start targeting a stroker (408cid or larger) block, built TR6060/T56 magnum, rear gears and lsd, then switch to a custom grind cam and shoot for 550rwhp+ n/a.
#525
You mean more fun. Just found a new diff with the 3.92 ratio that Im going to swap to, debating if Im going to order it tonight or wait till after the holidays. Then the LSD will follow, cause I have a feeling the stock diff wont hold long after the new heads go on
