SC400TT Project Car Stage II
#798
Two others that have been invaluable as well are:
- Dan Osypian
- Chaz Stuart
Ryan
#799
Scott has been invaluable to my project Dave. His knowledge of tuning and wiring up electronics is substantial. More than that, his willingness to help a friend is his strongest suit, IMHO. Thanks Scott.
Ryan
- Dan Osypian
- Chaz Stuart
Ryan
You're killing us here!
KC
#800
What can go wrong?
I'm going to try to get a video posted up today fo the start up. Wish me luck.
I titled this post "What can go wrong?". I did that because I have learned that when taking on a project as immense as this one has turned out to be, anything and many things may go wrong. Sometimes it's the complex things, other times it is the most simple of things that may be overlooked. This does not mean a person should not take on their dream project, it just means that Murphy is bound to come and take a visit.
This is where true friends that are knowledgeable, helpful and humble are a godsend. Most of us don't know everything there is to know, and I most certainly fall into that category. What I did know was that I could pay professionals for certain work, put into use what I did know, learn the things I did not know, and ask for help from my knowledgable friends that are willing to put in a helping hand ot two.
Just know that anything can go wrong, so pool your resources and prepare as much as you can, then move forward. I think that is one of the most important strengths to draw from: Be willing to keep moving forward, no matter what the obstacle.
Once we got to the point of starting, the car would not start. There were two issues:
The timing was a simple but big mistake. I should have gone over the timing once it was done to make sure the motor was in time, and I just assumed it was done right, one of the few things I did not go over after it was done. In fact, the faulty wiring on the injector lead was another item I did not check after having the wiring loom re-wired and the External MAP installed.
A huge lesson learned here: "ALWAYS GO OVER ALL WORK PERFORMED BY YOURSELF AND OTHERS TO ENSURE MISTAKES WERE NOT MADE". No matter how significant or insignificant the task completed was. When I built the motor, I went over each and every step 4 times. I am not stating to review every move 4 times, but review everything at least once.
The timing was another example of this. The person that installed it is highly competent and very careful. But, he had never set the timing on a 1UZ, and the Lexus manual was rather confusing on the timing marks. So, the timing was set to the cam trigger teeth which are located on the back of the timing gears instead of the very small, correct timing marks which are located on the front of the cam gears. I am revealing this so any of you that decide to replace your timing belt are sure to set it to the marks on the front of the gears.
Once the timing was set properly, the car fired right up.
Here's looking forward to driving the car soon.
Ryan
- Faulty wiring with one of the injector leads and the external MAP sensor for the transmission standalone computer.
- Mechanical timing was off
Ryan
#802
Ryan,
Glad to help get the problems corrected; although, it did test my patience a few times. However, just like anything else, it's a learning experience and well worth the time and effort to get familiar with the 1uz and the Autronic SM4.
And I'll admit the cam timing is something anyone could get wrong the first time on the 1uz. Unlike the 2jz motor the cam triggers on the 1uz are on the back of the cam gears and look like timing marks. It's an understandable mistake.
Good luck and continued success!
-scott
-scott
#803
Super Moderator
Location: Sideways on the Yellow Brick Road! < Thats KS!
Now off to the dyno and no videos like this!
http://www.youtube.com/watch?v=GepuJfZOis8
Or this!
http://www.youtube.com/watch?v=dSVFVahN3Rk
As you and I have talked, this is my greatest fear, This is the stuff that wakes me up at night.
Now lets see those start up videos!
Or this!
#805
Or this!
Or this!
Ryan,
-scott
-scott
Ryan
#808
Or this!
Or this!
#810
