Build Threads Details on Club Lexus SC owner vehicles
My ´97 SC400
Old 09-06-14, 12:53 PM
  #316
scENFORCER
scENFORCER's Avatar
^ Thanks, that is waht I want to hear
Old 09-07-14, 11:56 AM
  #317
Sc400NL
Sc400NL's Avatar
I follow your progress for a while now and its amazing to see the things you do
keep it up
Old 09-20-14, 11:23 AM
  #318
Boergy
Boergy's Avatar
HY!
Thanks SC400NL i have not much time the last days, but my AT-Simulator is near finished
i use 50watt resistors and a headsink to simulate the solenoids from the AT. (4-5-15-15 ohm)
with new 8-pin connector
today, i checked the CEL Codes:
P0710 gearbox oil temp sensor
P0753 solenoid A
P0758 solenoid B
P1755 Solenoid lock up
P1765 solenoid accumulator pressure
the last 4 can i simulate with my resistor-box. the gearbox oil temp sensor simulate i with a resistor. Toyota says 0,3k-Ohm @ -10°C and 65k-Ohm @ 110°C. i measured today 4,2k-Ohm @ 25°C in my garage.
tomorrow, i will install the resistor and make the 2 brackets for the heatsink
greets
Tom
Old 09-21-14, 07:29 PM
  #319
Rezist89
Rezist89's Avatar
one day i can do this
Old 09-24-14, 08:23 AM
  #320
Boergy
Boergy's Avatar
HY!
yeah! no CEL more!
my solution: a 47k-ohm resistor to simulate the transmission oil sensor
next step was to fit the brackets on the headsink
bracket in the car
installed
connected to the car wires and test!
i started the engine, CEL on, with my OBD-Scanner the failures deleted start again, no CEL more!
next step: Cruise Control Clutch switch install and connect and remove the gauge cluster to stick over the AT symbols to have a MT Cluster
the thread is a M10x1,25
greets
Tom
Old 09-24-14, 07:07 PM
  #321
oldManTan
oldManTan's Avatar
i love your thread, this is so well done and clean, awesome thread
Old 10-01-14, 07:22 AM
  #322
Boergy
Boergy's Avatar
Thanks!
last weekend, i take a video from outside
Next update the shiftboot was to high on the shifter, i searched a countersunk ****, but i found no one, the i like. i bought a TRD style black shift **** from Australia.
the fits, but was to high, also, i build my one countersunk TRD ****
6mm, 10mm driller, M12x1,25 tap and a step drill. original is the **** 63mm long and the hole 53mm deep, now is this 61mm deep and have steps
90% finished thread
deepest position from the shiftboot on my W58 Shifter (mk.IV)
fits perfect!!!
next steps: gaugecluster modify to mt, install superpro PU bushings on the diff.
greets
Tom
Old 10-01-14, 01:37 PM
  #323
Boergy
Boergy's Avatar
Next done SC400 MT gauges
Old 10-01-14, 01:58 PM
  #324
Sc400NL
Sc400NL's Avatar
as always , its perfect and clean , i have so much respect to see a fellow euro owner doing this type of mods
i know how hard it is for us in europe
Old 10-01-14, 09:15 PM
  #325
oldManTan
oldManTan's Avatar
you guys need to move to eastern europe lol. they don't care about anything at all there lol. my cousin is building an RX7 FC with a volvo V8 and a diesel turbo hahaha. i giggle every time i talk about it.
Old 10-02-14, 12:35 PM
  #326
Boergy
Boergy's Avatar
Hy!
Today, i installed the SuperPro bushings to the diff, easy to fit
original
SuperPro parts
installed and screws secured with loctite
next was the cruise control switch on the clutch pedal assembly. not easy to install, but ok the green-yellow wire cut and connected to the switch. And the clutch pedal correct adjusted, feels now better, oem
also cleaned the engine bay from the wires from the transmission, not 100% perfect, but looks better as before
and at last, a CEL comes today... P1780... PNP switch ok.. only thing the was other as on the day before, i removed all bulbs from the gaugecluster from the P,N... maybe this a problem? all days before no CEL. I installed the bulbs back (only N and L and 2), the next testdrives is on the weekend
greets
Tom
Old 10-02-14, 12:52 PM
  #327
Kris9884
Kris9884's Avatar
I found these for the PNP issue, maybe helpful?
https://www.clublexus.com/forums/sc-...lfunction.html
http://engine-codes.com/p1780_toyota.html
Old 10-03-14, 08:14 PM
  #328
Phoenyx084
Phoenyx084's Avatar
Great build!
Old 10-05-14, 12:38 AM
  #329
Boergy
Boergy's Avatar
HY!
Thanks!!!
i think, i found my problem with the noise from the release bearing. I installed a Spec Stage 3 for the SC300, not for the 3S-GTE or 3VZ Engine. A friend have a Spec for the 3S-GTE on stock to look on this pressure plate. maybe the are different in the high.
here a video with the noise. when i press the clutch pedal, noise is off
Old 10-05-14, 04:16 PM
  #330
scENFORCER
scENFORCER's Avatar
Uh oh, that's no good. Does it still drive ok though?
Quick Reply: My ´97 SC400
