Build Threads Details on Club Lexus SC owner vehicles
B-ver's Build Thread
Old 04-08-09, 10:36 PM
  #181
BattleVer
BattleVer's Avatar
I wish there was more of an update, the car is still in paint. Missing a couple things on the motor still. The valve lash is pretty far off and I dont have the shims to get it right. Think I need to have the valves cut down so I get in the range I need to just order shims from the dealer, unless someone in socal has some short 28mm shims. Think I may have found a clutch though which is good. And My web site has been updated after 6 years. I still need to fix alot of things but if you need web site work or a cool Tshirt, hit up www.kameezapparel.com
Old 04-10-09, 09:21 PM
  #182
jimmyXthai
jimmyXthai's Avatar
formula d has some pretty nice cars this year, yours will definitely be one of them
Old 04-11-09, 06:16 PM
  #183
Da Coupe
Da Coupe's Avatar
Can you recommend a good tuner for the Vipec V88?
Old 04-12-09, 09:22 AM
  #184
AD_SC3
AD_SC3's Avatar
Do you think your going to make Road Atlanta?
Old 04-12-09, 09:41 AM
  #185
Dv8
Dv8's Avatar
Originally Posted by BattleVer
Then I just wanted to show you guys the coil overs for this car. RSR I-Shocks, titanium springs, aluminum housings, 2 way adjustable. Right now its 16kg and 16kg. Probably not going to run a rear sway bar so this should be cool. I may end up dropping the rear spring rate down a bit but need to test them first.
Those are amazing coilovers, but whats the reasoning behind the springrates?
Old 04-12-09, 06:34 PM
  #186
BattleVer
BattleVer's Avatar
I asked Ueno at one of the D1 events what was on his car and thats what he was running so I figured its a good place to start.
At this point I'm not sure if it will be making atl. Even if I get the car running, I dont want to drive that far with an untested car.
Da Coupe, still looking for someone to tune it. Waiting on the software.
Old 04-12-09, 06:53 PM
  #187
Rix Sc400
Rix Sc400's Avatar
just continues to blow my mind
Old 04-12-09, 07:03 PM
  #188
Dv8
Dv8's Avatar
Interesting. Due to the unbalanced dynamics of the car I would assume use of slightly heavier springs in the front, perhaps 18kg even with proper weight dist.
Really what it comes down to is driver opinion. Seeing as I'm not driving your car, these decisions are yours
Old 04-13-09, 07:34 PM
  #189
BattleVer
BattleVer's Avatar
The 16/16 setup worked good with the stock power on my daily. Tracked it and drifted it a few times, though it was a little oversteerish for grip. I'll probably end up switching the rates once I get some testing in.
Put the bottom half together for the DVD,
Thank You Brian Crower, CP pistons, and Speed O Motive!!!
Old 04-13-09, 08:21 PM
  #190
AD_SC3
AD_SC3's Avatar
Well there is also next year Still I look forward to the progress
Old 04-13-09, 08:31 PM
  #191
chrisngo
chrisngo's Avatar
Nice so far! Keep up the great work.
Chris
Old 04-14-09, 08:50 PM
  #192
cazman
cazman's Avatar
in Formula D are you not allowed to tub the front end?
I fear that you will be hitting the upper arches alot. I do in my street car with 15kg springs at only 350mm CWG.
What was the height of your old street car? Pics or measurments?
The thing is its hard to tell if you are hitting the bump stops too, I noticed under braking becasue as soon as you hit them I would lock up.
In bumps it was harder to tell.
Just curious as the 4 main drift soarers in the world all use tubs, and I think they found the same reasoning as I did.
The upper arches are designed badly and dont allow for much space.
Old 04-14-09, 11:15 PM
  #193
BattleVer
BattleVer's Avatar
You cant cut behind the shock towers. You can do anything to the front section though. If I do end up with a problem, I'll just cut it out or make a lower body kit.
Old 04-15-09, 12:08 AM
  #194
cazman
cazman's Avatar
Thats funny you say that, I was thinking of lowering the front gaurd height due to this. Origin bars sit the lowest of any brand at the front too. (abnormally low compared to the sides and rear)
Old 04-15-09, 12:20 AM
  #195
BattleVer
BattleVer's Avatar
Yeah, I like the origin front bumper and their front fenders, just the sides and rear are kinda stock looking.
The car got primered today, I'll throw up a pic in the morning. Kinda tired. Got home not long ago from picking up a pair of seats almost 100 miles away. Only on my second beer and my eyes are closing fast.
Quick Reply: B-ver's Build Thread
