Water/chemical stains on 3IS wheels, how do you fix them?
Hi everyone, I recently purchased a certified 2014 3IS 250 for a great price.
The only downside to this vehicle is that there are stains on wheels which I've been trying to get rid of with no luck.
Anyone know of a way to get rid of these stains? Or am I going to have to completely sand them down and paint them again?
Thanks!
Thanks!
Man I'm also having the same problem!
One hot day after my girl was driving for 20 minutes, I sprayed the brake dust covered wheel with what I assumed was wheel cleaner, completely stained my wheels to black!
Well that's weak!
I had just bought that "ironx" let's see what happens.
Now if I had repeated that to all the wheels
It wouldn't have been so bad aIso I have no idea what was in that bottle.
Car is dipped btw
Car is dipped btw
i would say that after iron X or sonax to use a good buffing compound if it is still there. Remember its still paint after all and you should try to approach it as if it was any other surface. Try the detailing section or autogeek.net
What're the chances iron-x would fix the problem?
Power washed
I think it's working...!
Nope!
Nope!! God try tho
So it's been said that it's not a stain but a absent of paint.
Black base with thin silver on top.... Fuuuuuuuuuuuuuuu
Auto Detailing Master
This staining is a below surface defect... this is not something a chemical will remove.
It appears a chemical of some sort was used on the wheel and left to dwell for way too long, or perhaps used when the wheel was hot and dried very quickly.
In any case, this type of damage is going to require an abrasive to remove (hopefully), or else the wheels will need to be refinished.
For now, try to take some polish like Meguiar's M205 and apply a small dot to a clean microfiber towel. Work the polish into a small section on the wheel and see if it removes the stain. If not, grab a more aggressive product like Meguiar's M105 and try the same thing.
If neither of these products produce any noticeable results, it is likely safe to assume your wheel needs to be refinished. Unfortunately you are not the first, and wont be the last, person do have to deal with this... there are existing threads in here which result in the same conclusion.
