How to get this black stuff off my rims?
Just bought the car and figured I would be able to clean this black stuff off my rims by hand wash with a mitt but looks like it's brake dust that's caked into the rims. Thoughts on how to get this black stuff off?
Spray some Iron-X on it.
If it's actual brake dust, it will turn it into a bloody red color and hopefully break it down. Might need several hits of it if it's really bad.
If the chemical of Iron X does not turn red, then you are dealing with something different than brake dust.
Auto Detailing Master
It is very difficult to tell what I am looking at based on the photos, but here is the general approach to dealing with these types of things.....
If it is contamination above the surface, you will need to find a solvent of some sort to remove whatever it is that is on your wheels. Often times a tar/grease remover might work well, mineral spirits, etc etc. it just depends on what the substance is. A word of advice - always test the chemical in an inconspicuous area (barrel of the wheel) before spraying it on the face of the wheel to ensure there are no negative effects from using the product.
If the staining has penetrated the surface, you need to use some type of abrasive to remove some material in order to remove the stain. A typical compound or polish will usually do the trick, but if it is severe, sanding may be needed.
Hope that helps
-Zach
Hope that helps
-Zach
Well I tried cleaning it with Sonax Wheel Cleaner, then moved onto IronX and then I tried to polish it off with some Meguiars polish and nothing seems to take it off. Whatever it is, assuming it's brake dust is really caked into the surface. Is this something I should take to a professional to sand or is this something I could probably do on my own?
If you can feel it with your finger or fingernail, then it is safe to assume it is above the surface of the wheel and can be removed.
If you can't (which I suspect is the case), you may be looking at staining that needs to be professionally refinished.
I would seek out the opinion of a professional in your area.
-Zach
-Zach
I was thinking the same thing after noticing the stains are directional. Looks like the dreaded chemical etching.
TYPEONE8
Automotive Care & Detailing
13
05-28-11 10:31 AM
