Interior Cleaner for Lower Door
Hello, new Lexus owner here, IS350. I am looking for a product that can remove shoe scuffs from the interior doors (plastic areas). I've noticed people getting in and out of the passenger seat tend to leave scuff marks. Would something like Meguiar's 'quick interior detailer cleaner' work?
Thanks in advance, Dan
Unfortunately, you can't remove the scuffs since they are physical marring of the plastic surface. The only thing you can do is clean the area of dirt/dust to make the scuffs less visible. Any interior detailer will do the trick; however, buy one that provides a matte finish rather than gloss. Gloss finished tend to make the scuffs more visible.
When I think "scuff mark", I think marks left by dark rubber and leather shoe soles. There's a colored deposit, and whatever physical marring may have occurred can be made less visible once the dark mark is removed.
For these I use something stronger than interior detailer and microfiber. OPC with a terry towel, and a soft but stiff bristle brush (like the one that comes in the Leather Masters kits) if necessary.
Auto Detailing Master
Great responses guys!
These 2 are right on the money... to summarize - if the plastic has truly been damaged (scratched, scuffed, whatever), then there isn't a simply way to repair it. You can do your best to hide it with an interior dressing like 303 Aerospace Protectant which will help to darken the area (if your panels are black... if they are tan, I am not sure what to recommend).
On the other hand, if the plastic itself is not damage, and it is just material transfer from a rubber shoe sole, then the rubber marks should come off with some cleaning. I'd recommend something like Einszett Plastic Deep Cleaner paired with a MF towel or a brush depending on the texture of the plastic.
Regular Window cleaner works good for me for any dirt marks on any part of the car with tan plastic trim. I spray it then wipe with a wet microfiber cloth. All marks come right off it works really great in my opinion.
Define "regular window cleaner." Some of those contain ammonia and alcohol, which are damaging to plastics, while others use different ingredients. Regardless, I would use 303 or another vinyl/rubber cleaner for the surface.
I've used Meguires Quick Detailer and Areospace 303 to seal with excellent results.
Found that the plastic on the bottom of the doors on the GS350 is different than the rest of the plastic on the doors (seems slightly softer).
When I first cleaned the door kick panel with Meguiar's Quick Detailer it seemed like it was leaving streaks and softening the plastic (unlike the rest of the plastic on the door panel), so I didn't rub it down too hard. But as soon as it dried it looked fine and once the 303 was applied, looked brand new again.
Regular window clean I mean windex glass cleaner . It gets the plastic spotless no matter the stain . I know Some may say we'll it contains this chemical al or that chemical thts bad but it has worked for me with no issues for many years. Just be sure to spray it in a fine mist and then wipe it off with a wet cloth .
There are many products designed specifically for this type of material, they have been mentioned in this thread, and they have so many uses that there is no reason not to get a bottle. It's not like a product that you use once and have sit on the shelf for years.
What is "oil-based silicone"?
I assume he was referring to silicone based dressings that leave wet, but greasy looking appearances. Many consumer based dressings for interiors and tires contain silicone because the general population perceives a shiny rubber of vinyl surface as "detailed", when the reality of it is these products are not the best choice for maintaining your vehicle.
Water based dressings will help to nourish the plastic, vinyl or rubber instead of potentially harming them.
LexusVDS
Automotive Care & Detailing
09-26-16 03:09 PM
Reyngel
07-25-06 12:24 PM
