Best tool to steam clean wheels?
Hi All-
I'm interested in purchasing a steamer to clean my wheels. Is it correct that steam cleaning wheels is very effective? Also, what is the best/recommended machine? I have seen several steamers on amazon, but it is not clear which one would be best for wheels? Any tips much appreciated.
Auto Detailing Master
Most consumer steamers aren't powerful enough to quickly and efficiently clean wheels. You'd need an industrial/professional grade machine with a high output temps and pressure.
In general, cleaning your wheels with soap, water, and the appropriate tools will be much quicker and easier. (And cheaper!)
My wheels are simply protected with HydrO2 and I just need to rinse them, wash them with soap and water using my wheel woolies for the barrels and boars hair brush for the faces, and then rinse again and they are spotless.
If you've got heavier buildup, a wheel cleaner will provide some more cleaning power, but you must also be sure you're washing the wheels properly.
I'm afraid your installer might not clean the wheels well enough before topping it with Opticoat. Therefore whatever build up is underneath the Opticoat and that prevents you from cleaning it out lol.
Jbreezie, why do you copy exact avatar and signature like my friend Glock47 has???
The wheels are the very first thing I wash. I rinse them off pretty well, you can see the brake dust come off. Then I use a wheel brush and MF mitt to clean the wheel faces with the soap bucket. Then rinse off. Then when I dry them later, I see a dirty towel! When I dry my car off, I rarely see a dirty towel! The wheels are clean but maybe I was expecting the white glove clean.
Maybe because I don't clean the barrels.I clean whatever I can reach with the MF mitt and wheel brush.
This is my brush and I use a wal-mart MF Mitt. I use Reset for my soap.
What is your exact cleaning process? What tools are you using to clean the wheels?
haha I'm sure it's coated because it beads and it's fairly easy to rinse off. Before the dust would not come off that easily without scrubbing.
Unless your wash mitt got to clean every spoke and cranny, your wheels would still have brake dust in some places so when you go dry it with your towel you will see brake dust. Try using a towel with soapy water and wipe in the same manner as you would dry, see if that helps.
My wheels are also opti-coated but I use 2-4 brushes when I wash them to make sure there are no brake dust left behind (even on the caliper)
The wheels should have their own bucket, brushes and pH balanced solution. Do not use your wash mitt or wash bucket for the wheels.
I hose mine with a high pressure washer and then spray them with poorboy's wheel cleaner and let it sit while I wash the paint.
I then use whatever water left from the wash bucket and pour that into the wheel bucket. I have the OXO brushes and I start going over the wheels one by one. Hose them off.
If you got your own garage, you can use a leaf blower to dry off all the excess water.
I just ordered a steam cleaner so I can use it for cleaning a 2001 Subaru Forrester interior, but I will try that on the wheels and see how well it works.
In answer to your question. This is the steam cleaner that I bought:
VX 5000 Steamer Direct.............
I didn't just buy it for the car though. I use it to clean the leather, the grout in the house and shower, the toilets, windows (they gave us a squeegee with it that hooks to the hose).
I think that it was money well spent because I can do so much more than just use it on cars.
He gives you a boat load of different brushes, tips and attachments with it too, which is good because the price of all of those things add up.
Good Luck!
By the way, I have NO affiliation with the above vendor, other than being a Satisfied Buyer!
Good Luck!
