Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Iron X question
Old 03-10-15, 05:30 PM
grsams
grsams's Avatar
Default Iron X question
I recently ordered Car Pro's Iron X from DI. Aside from the awful rotten egg/perm smell, I am excited to see how well this stuff works (when the rain ceases). My question is, although I did not see anything on the bottle saying that it was concentrated. For those that have used or currently use, did you dilute? If so, what ratio to distilled water did you use? Thanks in advance.
Old 03-10-15, 06:27 PM
jowsleyyy
jowsleyyy's Avatar
From their website It doesn't seem like you need to dilute it.
DIRECTIONS:
1.-Shake the bottle.
2.-You can cover the surface with Iron X by spraying it everywhere but that can be wasteful. I recommend that you spray as needed and spread it with a small sponge or applicator to cover the entire surface. You may also consider using an atomizer type spray bottle or HVLP gun. In any case evenly cover the surfaces you wish to decontaminate. The product is strong so you don’t have to be wasteful. Just make sure it contacts the entire surface.
3.-Allow the product to dwell for 5 minutes in the shade. Do not allow it to dry in the sun. On light colored paints you will see the product dissolving ferrous particles as it turns color. On darker colored paints everything is happening in exactly the same way. It’s simply more difficult for you to view the color changing affect. I have read people saying the product works better on lighter colored cars but that is illogical and is not the case. It works the same regardless of car color.
4.-After allowing to dwell take a damp (not soaked) grout or other paint safe sponge (or other media if you prefer) and agitate the surface.
5.-Thoroughly rinse the surface.
Don’t forget to rinse your media out also. I like to have a dedicated Iron X sponge but that isn’t necessary.
Old 03-10-15, 08:14 PM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Do not dilute!
In fact, for best results it should be applied to paint that is mostly dry.
Let me know if you have any other questions.
-Zach
Old 03-10-15, 10:25 PM
Jetfire
Royale with cheese
Jetfire's Avatar
I did what was said above when I used Iron X and Tar X. Let it dwell in the shade on a dry car. It works great!!
Old 03-11-15, 10:46 AM
FSportIS
FSportIS's Avatar
It is fun to watch your car bleeding... with ironX. You will be like bleed more baby bleed more!!!
Unfortunately, my cars don't bleed much because they are not much contaminated. Both happy and sad.
Old 03-11-15, 10:50 AM
zmcgovern4
zmcgovern4's Avatar
Originally Posted by FSportIS
Fortunately, my cars don't bleed much because they are not much contaminated.
^ Fixed
Old 03-11-15, 11:09 AM
FSportIS
FSportIS's Avatar
I meant "unfortunately" because I am addicted to see the car bleeding with ironX due to contamination. Put ironX on the dirty wheels and holy macro--it bleeds like the end of the world.
On our cars, sign of little bleeding suggests that we have taken care of the cars well.
IronX ONLY cons is damn that thing stinks like s*** lol.
Old 03-11-15, 12:09 PM
zmcgovern4
zmcgovern4's Avatar
I knew what you meant... was just messing with ya.
I hardly even use IX on my car because I know it is essentially a waste since my car remains pretty darn clean. I'll use it once a year.
Old 03-11-15, 02:57 PM
WylieKylie
WylieKylie's Avatar
I've been using it every couple of months from spring through fall. White car, daily driven, The car always bleeds more than I expect! You never get used to the smell either, NASTY!
Old 03-11-15, 03:02 PM
GSteg
GSteg's Avatar
The smell is pretty bad. I bought the lemon scent to see if it's any better. I don't use it on my paint though, just the wheels.
Old 03-11-15, 08:15 PM
grsams
grsams's Avatar
Yeah, I purchased the "Cherry Scent". Not sure what part is cherry though.
Old 03-11-15, 08:24 PM
popping
popping's Avatar
They both smell like parc!
Old 03-12-15, 06:32 AM
GSteg
GSteg's Avatar
Maybe they took the scent from rotten cherries.
Old 03-12-15, 07:07 AM
grsams
grsams's Avatar
Very true I actually thought of swabbing my nose with rubbing alcohol to get the smell out. I made the HUGE mistake of bringing this stuff indoors and pouring it into a spray bottle. I had to break out candles for the rest of the evening.
Old 03-12-15, 07:49 AM
zmcgovern4
zmcgovern4's Avatar
I store all of my supplies indoors through the winter... including gallons of IX. It is fine as long as you keep the bottles sealed up.
Or maybe I've just gotten used to it over the years
Quick Reply: Iron X question
