IS - leather seat problems
this is my first beige leather in a lexus. previously had black leather but this is totally different from it. it's very hard to keep it clean and the leather seems very sensitive and weak. the top layer is coming off already and cracks and rips everywhere. i can't wear dark washed jeans because it stains so badly. btw pic was taken after it was cleaned with leather cleaner. are people with beige leather having the same problems? the car only has 39000 miles and the leather started to peel only at 30000. is this normal? never had peeling or cracking problems in black leather before.
is this normal?
is this normal?
If you protect it properly, then it is not normal. Otherwise, I think the top coating has wear off and then someone possibly uses some harsh cleaner on it. I suspect this is exposed to sun UV damage too.
I have the same color leather on my old IS350 2006 but I always use 303 aerospace protectant to prevent UV damage and stain problem. My leather still looks brand new with some wrinkle here and there.
In a matter of fact, I did deep clean all my interior leather yesterday with vacuum and Meguairs APC diluted at 15:1. I finally apply a Carpro Leather &Vinyl coat on it and now they look and feel soft, better than brand new.
I have to agree with you that keeping it clean isn't easy but with 303 product or some leather coating, it should prevent stain, dye transfer, dirt, and soiling.
i've been using what lexus recommended me to use. bought it from lexus service department.
geez...worst leather ever.
It looks like a case of neglect. The clear coat has peeled off. You should regularly clean your leather, especially when it is light colored. It should be regularly treated with a UV protectant and coating to prevent ink/dye transfer. Leather master makes a number of products that may help in your situation.
Sure doesn't seem normal to me. Might be worth complaining to Lexus. Worst that can happen is they won't help. Please note, with these treated leathers most leather conditioners don't do much because the product rubs off the surface as soon as you sit in it. So a lot of them will not offer any UV protection. There are a few products that are supposed to help with UV protection of the treated leathers. So you might want to investigate that, although I think it is too late for your seats.
i have the same color seats. 50k miles and looks nothing like urs.. i clean as needed and use conditioner on it weekly. i also make sure never to put any sharps in my back pockets when i drive for ex., keys, switch blades, money clips etc. oh and i also try to step in and out of my car. dont slide in or out
mine is starting to look unappealing like your seats and I just hit 36,000 miles!
I put leather conditioner/cleaner once a month and let it sit and cure on before sitting/getting in or out of the vehicle. I got the nice nice window tint all around and use the sun visor religiously but it still is starting to wrinkle like yours....but no dye transfer that I have noticed.
mafitch
02-05-13 06:10 PM
