Tips on how to protect a certain area of carpet
Try this one --- I have the one with the print but they have a version without print but limited to a certain roll size.
It is not super thick and I believe it is the one used in the dealership showroom. However, the idea is to remove it from time to time. I was told it is better to remove it every 1-3 months depending on the temperature. I use it primarily to cover the driver's foot area during the winter as the rubber mat does not cover some critical areas where I would have needed to clean it if without the film.
http://www.americover.com/auto_carpe...r_688_prd1.htm
Also you may contact them and ask if they could get one without the print if you look for a particular roll size. Company seems to be in CA and shipping was considered pretty quick in my case.
And I just use a OLFA knife to trim the film to sizes I need.
Home Depot sell sells this adhesive carpet protector on a roll.
http://www.homedepot.com/p/Roberts-2...0-12/202020269
It is typically used as runners in new home open houses. I've used it and it is pretty tough. You can add layers if needed. Sticks pretty tenaciously.
tsxnbp
06-19-15 04:25 PM
Traxxer
05-20-13 08:38 PM
