Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
CarPro HydrO2... buy it!
Old 02-05-15, 04:54 PM
  #121
JDR76
JDR76's Avatar
Received 1,604 Likes on 1,022 Posts
Originally Posted by FSportIS
That is crazy. I have Opticoat 2.0 too and streak from Reload, stain from bird bombs all disappear in a few weeks like magic. What I learn is that the sun uv rays break down the stain or whatever streak. Are your car parked outside and exposed to sun 24/7 like mine?
I don't have streak with Hydro2, only Reload on a dark blue car though. No streak whatover on a white car.
No, I'm in Seattle. We don't have sun in February.
But otherwise, no, it sits in my garage at home or my work parking lot.
Old 02-06-15, 10:28 PM
  #122
darylrsv4
darylrsv4's Avatar
Figures, got my Reload today and the bottom of the bottle is cracked and was leaking. Hopefully Detailed Image will send me another.
Old 02-07-15, 06:47 AM
  #123
darylrsv4
darylrsv4's Avatar
Does Reload need to be diluted or spray right out of the bottle?
Old 02-07-15, 07:00 AM
  #124
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
DI will gladly help you out... If you have any trouble, let me know and I'll help to get you a new bottle.
Reload does not need to be diluted, however it can be to make the product more economical. If you're using it as a stand alone sealant, I'd use it full strength. If you're using it as a topper or if you use it regularly, I'd dilute it 1:1 or 2:1 (distiller waterroduct).
-Zach
Old 02-07-15, 07:06 AM
  #125
darylrsv4
darylrsv4's Avatar
Appreciate the quick reply Zach. Was about to head out and wash my car before the sun comes up. I just sealed and waxed last weekend, think I'll get any streaking with Reload at full strength?
Old 02-07-15, 08:10 AM
  #126
zmcgovern4
zmcgovern4's Avatar
The Reload formula was tweaked (in 2014) to provide a stronger, more durable layer of protection. With this change in the formula, streaking is more of a concern unfortunately (2014 V1). While some users do not report any issues, others see streaking, however this can be minimized by diluting, or by wiping with a damp towel followed by a dry towel. A 2nd tweak (2014 V2) was later released to help make the product easier to use.
Check out this article for more info: How To Reload (Featuring Reload 2014 V1)
-Zach
Old 02-07-15, 10:38 AM
  #127
darylrsv4
darylrsv4's Avatar
Again, thank you. We are fortunate to have such a resource like yourself on CL.
Old 02-07-15, 04:36 PM
  #128
mcolommena
mcolommena's Avatar
Originally Posted by zmcgovern4
The Reload formula was tweaked (in 2014) to provide a stronger, more durable layer of protection. With this change in the formula, streaking is more of a concern unfortunately (2014 V1). While some users do not report any issues, others see streaking, however this can be minimized by diluting, or by wiping with a damp towel followed by a dry towel. A 2nd tweak (2014 V2) was later released to help make the product easier to use. Check out this article for more info: How To Reload (Featuring Reload 2014 V1) -Zach
hi Zach. How do we know if we have v1 or v2?
Old 02-07-15, 05:53 PM
  #129
zmcgovern4
zmcgovern4's Avatar
Not much of V1 was shipped once the streaking issue was brought up... Every bottle should have a date on it, you can contact CarPro for better data on when exactly V2 was manufactured. I don't have that info personally.
-Zach
Old 02-07-15, 11:16 PM
  #130
FSportIS
FSportIS's Avatar
I think v2 was released in late 2014 particularly in October.
Old 02-14-15, 11:06 AM
  #131
itsjdmyo
itsjdmyo's Avatar
Just tried the Hydr02 this morning after my car wash and it worked like a charm! Results were exactly in the video you see in the original post. I sprayed it on small sections at a time and then quickly sprayed it off with a pressure washer.
You can quickly see the water just start beading off the car. I used an 8oz bottle (1:3 mix) and still have some left. I am very happy with the results and will continue using it.
Old 02-14-15, 11:34 AM
  #132
zmcgovern4
zmcgovern4's Avatar
Originally Posted by itsjdmyo
Just tried the Hydr02 this morning after my car wash and it worked like a charm! Results were exactly in the video you see in the original post. I sprayed it on small sections at a time and then quickly sprayed it off with a pressure washer. You can quickly see the water just start beading off the car. I used an 8oz bottle (1:3 mix) and still have some left. I am very happy with the results and will continue using it.
Awesome! Thanks for sharing!
Old 02-14-15, 08:59 PM
  #133
jv6792
jv6792's Avatar
how does hydr02 compare with the traditional sealants? is the ease of use the only advantage to this product or is it really that efficient in terms of protection?
Old 02-15-15, 05:53 AM
  #134
zmcgovern4
zmcgovern4's Avatar
The silica based formula is very chemical resistant. It provides a glossy finish that is more characteristic of a coating (ie a 'hard candy' type of look), beads and sheets water very well, and is very quick to use.
Traditional sealants are also good, but the main advantage to hydro2 is the time savings... You can seal the paint, wheels, and glass in 10-15 minutes during your car wash where there is much more time involved with using a traditional liquid sealant.
Not everyone needs the time savings though, so if you enjoy the traditional method, stick to it
Old 03-03-15, 08:43 AM
  #135
darylrsv4
darylrsv4's Avatar
Forgot to post how much I like the Reload. By far one of the best products I have used. Love the slickness that it leaves and how much the water runs off the car when washing.
I was hoping it would help keep the dust down on the surface of the car here in dry So Cal but doesn't seem to..
Quick Reply: CarPro HydrO2... buy it!
