Spilled Mustard on Leather
Your help would be greatly appreciated. I have a 2005 LS 430 with heated/cooled seats - cashmere color. A friend of mine spilled some mustard from her hot dog on the passenger leather seat. I have not been able to get the stain out. I tried a 5 to 10% Woolite solution and also a Lexor Leather Cleaner solution. luckily the mustard stain doesn't show through very bad.
Any suggestions on how to get the stain removed?
Leather Master Protection Cream would most likely have prevented the stain from leaching into the topcoat. Once any stain gets time to penetrate the topcoat you will have an almost impossible task ahead to remove it. You might try the LM Ink Lifter but stains, once set, often require restoration and no amount of cleaning will work without damaging the leather. The longer the stain sits on the topcoat the deeper it penetrates. Thus, to remove the stain would require removal of some or all that topcoat.
Thanks for your help
I used Lexor leather cleaner and it did a decent job at removing the mustard stain. Some of the mustard had fallen through the holes in the leather which I know I'll never be able to remove. Lucky that I have the cashmere color leather. What stain that is left blends in nicely with the color of the leather.
