Up Close & Personal: Daytona Speed Master PRO Wheel Brush!
Former Sponsor
"The quality of life just went up!" I enthusiastically proclaimed after testing the first sample of the just-introduced Daytona Speed Master PRO Wheel Brush. That was shortly followed by "this thing is built like a tank!" and "definitely worth the wait!"
The Daytona Speed Master PRO Wheel Brush is the answer to hundreds of emails and dozens of phone calls from loyal Autogeek customers over the years asking for a wheel brush that could be used, abused, washed and reused thousands of times. The wait is over because the Daytona Speed Master PRO Wheel Brush has arrived.
The Daytona Speed Master PRO Wheel Brush was designed for the detailer that requires a brush built to withstand the rigorous use of every day wheel cleaning. From the half-inch thick, heavy-duty non-slip polypropylene handle to the chemically resistant Nylex bristles, the Daytona Speed Master PRO Wheel Brush was designed to outperform and outlast any other wheel brush.
Design
The Daytona Speed Master PRO Wheel Brush features the same chemical-resistant Nylex bristles found on the popular Daytona Speed Master Wheel Brush and Junior models. These unique bristles are gentle enough for sensitive wheel finishes but still effective for loosening brake dust, dirt and grime. Like the other Daytona Speed Master Wheel Brushes, the Nylex bristles on the PRO model regain their shape, even after years of use.
Construction
The aforementioned Nylex bristles are attached to a half-inch thick, heavy-duty non-slip polypropylene handle. This stiff, dare-you-to-beat-me-up handle is the biggest difference from the flexible handle of the other Daytona brushes. The heavy-duty handle of the Daytona Speed Master PRO Wheel Brush doesn’t flex or bend which enables maximum agitation so even the most neglected wheels are easily cleaned.
Brake Dust Beware!
The Daytona Speed Master PRO Wheel Brush enables you to remove ferrous brake-dust particles with ease. By combining the proven cleaning ability and gentle nature of chemically-resistant Nylex bristles attached to a long, heavy-duty polypropylene handle, you’re able to clean deep within your wheel barrels, removing brake dust and grime in places unreachable with other wheel brushes.
Remove the time and effort associated with wheel cleaning and clean your wheels with the Daytona Speed Master PRO Wheel Brush.
UCrazyKid
IS F (2008-2014)
09-27-12 08:56 AM
