2011 RX350 - 18" Aluminum Alloy Wheels & Brake Dust
Anyone have success with a good cleaner for the stock aluminum wheels?
Brake dust accumulates fairly heavy after 400-500 miles of city driving. I Use Meguiar's foam cleaner to keep tires clean which works very well. Not satisfied to try their wheel cleaner. And dont want to risk damaging wheel finish either.
Also reading on amazon, that some wheel cleaners also cause brake assemblies to get stained/discolored. Definitely dont what that.
Any helpful suggestions on wheel care?
No, I don't play soccer!
I use Sonax on my alloy wheels with superchrome finish. It goes on green and turns red as it reacts with the brake dust. Granted I don't have that much dust but I want to make sure they're clean. I also put wheel wax on every two months so the rims are easier to clean.
There are other cleaners out there but I like Sonax the best. All the CL vendors here carry it.
I use the Sonar wheel cleaner once in a while (only if it is super dirty). It is quite an
expensive product so I really use if there is a lot of dust/debris/grime etc.
For weekly washes, I use the Meguiar's All Purpose Cleaner Plus on the wheels (1 gal bottle) and I just dilute it/use it in my own spray bottle. The brake dust are pretty easy to clean on Lexus cars. A decent cleaner and a good brush will get the job done quick.
Good thing about the Meguiar's APC plus is that I can use it for cleaning wheel wells and engine bay because the 1 gal bottle is much cheaper than buying wheel cleaners and engine degreasers separately from stores like Walmart or Oreilly.
I haven't driven the new RX enough to comment on the amount of brake dust, but I can tell you that my CTS has brake dust galore. I use Meguiers Gold car wash and once I am finished with the entire car, I just get out my wheel mitt and do the wheels. It seems to do a good job and no other special products to purchase.
Carver, I am contemplating the use of ceramic pad on the CTS because of the dust. Can I just swap our the pads or will I require a change in rotors also. I was told some time ago that there are special rotors for ceramic pads, but it sounds a little hokey.
No special rotors are required. If your current rotors are in good shape the ceramics will adjust to them in a few days. I've only used Akebono so I can only speak for them but dust is over once they go on.
I have used several products over the years and have found that the Meguiar's Quik wheel detailer works very well in eliminating the dust and forms a barrier to it sticking. I have not encountered ANY discoloration on wheels or brake components. My wheels are usually clean, polished, and I hit them with the QWD after. Wash after wash, the dust just comes right off. On the DD, which has alloys (no chrome), it was as simple as spraying it on and wiping it off. Subsequent washes have been a breeze.
It can be tough to find in stores, which is odd, but I know they still make it.
This is being it.
Big Mack
This is being it.
Big Mack
I have been using Meguiar wheel cleaner and eagle one wheel cleaner on my other car. One of those product is causing some discoloration on some of my brake parts, I am not sure which, but I will stop using both. On the other hand, the wife's RX450h almost produce no brake dust. I can go about 2 months between cleaning the rims and it is still pretty much dust free.
Also, I wouldn`t leave the cleaners on the wheels for so long. A quick spray, 30 second scrub and rinse each wheel individual and right after scrubbing would help eliminate the issue you are having.
Just some pointers =)
If you have done all of the above, then I guess try an all purpose cleaner and dilute it to make it a light duty cleaner which is less strong.
If you are using the Meguiar`s and Eagle one wheel cleaners sold off the shelves, then they should be safe for all wheels and what not and should not cause any problems that you are experiences. These wheel cleaners are packaged to cater to the needs to many consumers and thus application is simple and the cleaners itself is not super aggressive or anything.
You might want to try the Sonax Full Effects wheel cleaner as a lot of people have positive experiences with that product. I`ve used it and I think it is as good as Meguiars wheel cleaner but the Sonax is just more expensive and you get less of the product.
Sonax can be expensive but I don't use it every week. I should have mentioned that. I'm still nursing a 5 liter container I bought from a CL vendor last year. The other times I use regular wash with a microfiber mitt. It works for me.
This is being it.
Big Mack
This is being it.
Big Mack
Former Sponsor
You may want to clean up the rims more frequently. 400 plus miles is quite a bit and brake dust will accumulate.
Sonax Full Effect Wheel Cleaner should do the trick.
You may want to apply a wheel wax like Prima Wheel Armour on it after to make life easier when cleaning your rims.
dvanhoof
Automotive Care & Detailing
01-15-18 07:10 PM
