Why car soap/shampoo?
I've been washing cars with water only my entire life but now that i got my 300C i was wondering what's the difference if I use water and if I use soaps?
And which soaps are the best ones?
I'm not a chemist.
But you wash dishes with detergent because the suds aid in dirt removal- surfactants in the soap ease dirt and oil removal.
I would also imagine that there would be a lower chance of scratching a vehicle when washing with a soap, since it is less abrasive than washing with water.
Also, it may sound corny, but it makes washing a car funner. The fragrance and appearance of suds makes an auto enthusiast enjoy washing their car. At least it does for me- otherwise I would just let the rain wash it.
I'm not a chemist.
DO NOT USE DISH SOAP - it will strip off the wax (which also helps protect the paint from scratching).
Use something like Meguiars or Armorall soap that has some wax built in. It helps maintain luster and a mirror finish in between waxes.
And, DO NOT USE DISH SOAP!!!!!!!!!!!
With 50 years making shampoo, and Im not joking, soap is better. Shampoo has a component that is pretty strong and if by any chance you dont take it completly off the car, your clear coat will be damaged. So soap is better. Ideally soap for washing cars offcourse
MEGUIARS car care products HANDS DOWN !
The advantage of car shampoo is it is able to lift dirt without damaging the car's clear coat and paint. You will also get nice water beads as car shampoos have protective agents that goes onto the paint as you wash the car.
Never use dish detergent because that will just strip your car's wax.
Eimann Fabrik Auto Spa Gentle Shampoo & Conditioner quickly removes the toughest road grime without using any strong, detergent, cleaners. Auto Spa Gentle Shampoo contains the latest in German surfactant technology and surface conditioning oils combined with TUFF SUDS II, an agent that puts cleaning punch in the suds' walls to clean with out surface abrasion.
This shampoo removes dirt and oily road grime but will not strip off existing wax or sealant coatings. Eimann Fabrik Auto Spa Gentle Shampoo is pH-neutral making it safe for all surfaces and creates mountains of suds even in hard water.
Formulated with TUFF SUDS II foaming technology, BLACKFIRE Gloss Shampoo creates mounds of rich suds, even in hard water. This new foaming technology uses cleaners and lubricating polymers suspended in the bubble's walls to scour away the toughest films and road grime without affecting the protective wax or sealant coating. You can feel the difference using a top quality shampoo. Your sponge or wash mitt just glides over the surface.
In addition, Gloss Shampoo is fortified with the same acrylic, super polymers used in All Finish Paint Protection. These polymers increase washing lubricity, encapsulating loosened grit to reduce washing swirls. They also improve water sheeting to prevent water spotting. This makes Gloss Shampoo an excellent choice for washing black, red and dark color vehicles.
Plus, a bonus!
Some of the polymers remain on the surface after drying, increasing surface luster and water sheeting. In addition to complimenting BLACKFIRE's shimmering gloss, these acrylic polymers can also be used over carnauba waxes making BLACKFIRE Gloss Shampoo a truly universal shampoo.
Meguiars Hyper-Wash is an extremely concentrated car soap which provides thick, rich suds even when diluted at a ratio of 400:1. Only one oz. of Meguiars Hyper wash is all you need when filling a 5 gallon wash bucket! Great for high-volume detail shops, one gallon of Meguiars Hyper-Wash provides enough soap concentrate to safely and gently clean over 100 vehicles. Meguiars Hyper-Wash is biodegradable and gentle to all paint finishes.
To reduce or eliminate washing swirls, you must keep removed grit in the wash bucket. This is accomplished by using the Grit Guard Insert in the wash bucket. This simple plastic grid sets in the bottom of your wash bucket.
As your sponge, wash mitt, pad or wash brush is rubbed against the Grit Guard Insert, gravity causes grit and sand particles to settle to the bottom of the pail.
Your wash water stays "scratch-free" clean! When you're done washing, you'll be amazed at how much grit and grime has settled in the bottom of your wash bucket.
Plus, a bonus!
Wax within car soap is more of a novelty in my opinion. Doesn't really offer any protection. You should be using a separate wax (not a spray) or sealant. But if you're using plain water, you're probably not doing that anyways.
