Repaired my own curb rash
Well, I never thought I'd be posting in this forum. I usually find my answers here, but for those who couldn't find the answer on how to do a DIY on rash repair, I thought I'd briefly share my experience.
What I used:
- Electric Sander/Polisher (with 180 grit sandpaper)
- 320,600,1000, and 2500 grit wet/dry sandpaper
- Mothers Mag/Aluminum Wheel Polish
- Dremmel tool (not Dremmel brand)
- Ice cold Gatorade (weather was HOT)
All I really did was use the sander to grind down the rash marks. Once they were smoothed out, I sanded working up from 320-1000. I then wetsanded with 2500. Then I used Mothers wheel polish.
Sounded complicated after I did research on how to do it, but with a steady hand, I grew some ***** and tried it. Wasn't as hard as I expected it to be.
Overall I'm happy with the results. I really didn't want to spend $50-100 per wheel for repair. I'll probably spend more time to take the rest of the clear coat off of the lips (I think it's from the factory [Work Wheels]) since they're starting to fade/dull.
I didn't take specific pictures, but just took pics whenever my hands were clean haha.
Began with:
Halfway through:
Pretty much finished:
Enjoy!
Oh yeah, the process took me about an hour for two wheels.
What I used:
Began with:
Halfway through:
Enjoy!
BahHumBug
any pros mind chiming in to let me/us know if this is similar to how its done in the big wheel refurb places? if so then hot damn, i'll be trying this out within a week.
would better results comes from attempting to file down the rash before hitting it with the sanding wheel? this should help prevent the sharp edges from chewing up the sanding pad as well as require less material overall be removed.
Thanks for the comments everyone. I don't recommend anybody to do this. If you're nervous, I'd suggest taking it to a pro. I was kind of in a whatever mood and if I messed up, I was willing to pay a pro after (but way later as it wasn't a priority to repair wheels)
Good Job. I did this as well on a set of some used 20's that I bought a while back. The clear coat was pitted and some rash. I used the dremmel on the serious areas and hand sanded after going to higher grits and removed the old clear coat while i was at it. Got the lips shinny.
Dallasguy1
11-01-17 07:41 PM
