View Poll Results: Lexus paint-clearcoat is weak and worthless. Should we unite in a class action suit?
I agree the the weak paint-clearcoat issue, count me in the class action suit against Toyota-Lexus.
31
46.27%
I don't agree, the paint-clearcoat is absolutely perfect just the way it is!
16.42%
I don't agree, the paint-clearcoat is weak, yes, but it does conforms to the US Federal regulations.
25
37.31%
Voters: 67. You may not vote on this poll
Lexus paint-clear coat. Should we unite in a Class Action Suit? POLL INSIDE
#46
Warrionex, If you go back through all 589 of your comments and threads you will find that there is a definite pattern in your words regarding legal action against Lexus or whoever. I'm simply stating that I've noticed this pattern and pointed it out to other CL members. I mean, really, a class action lawsuit against Lexus because your paint is too soft and chips easily??? Come on, man. Do you realize just how silly that sounds?
Maybe your real class action lawsuit should be against all of the dirt and gravel truck companies. It's their trucks, after all, that cause all these chips to begin with. Leave Lexus out of it, it's not their fault.
You obviously know that there won't be any case here if Toyota abides to the rules and regulations but I insist that you let everyone speak themselves on how the fill about it. Man, let everyone vote, that's it!! How difficult is that to understand?
And let me tell you, your blind defense against Toyota/lexus it's very suspicious. What if the paint is mix with cheapo material to save cost and receive higher profits. This is speculative of course but it is always good to investigate everything. Why the paint is sustancially better in Mercedes than in Lexus? Why? I don't know. But don't you think people has the right to know or at least ask Lexus about it? Some changes could be made in the process. Don't you think so! I know your are with me on that.
Regards,
Warrionex
#47
I would be happy if Lexus would pay at least half or better yet 75% the price to get the hood and front bumper repainted which is where most of the problems are at. As for legal action I think making them replace the far too common broken door lock actuators for free instead of us paying around $500 at the dealer for their design defect is more appropriate for a class action suit.
#50
Wait, the EPA isn't done destroying our paint just yet. If you don't like the brittle water based paint mandated by the EPA rest assured that they are still actively regulating paint and paint shops.
Source: http://www.asashop.org/takingthehill/
The actual EPA proposal is linked in the source.
The U.S. Environmental Protection Agency (EPA) has released a new proposed Auto Refinishing Regulation... (Sept 17, 2007)
#53
Even a safety issue I doubt would get resolved either, there is a problem with the lower ball joint design in GS sedans in which they have been failing around 90K miles and over which causes a bunch of suspension damage as well as can be extremely dangerous if the car is traveling at over 30mph, Lexus has done absolutely nothing to address this design defect so people who do not read up on Club Lexus or other Lexus forums will not really know that there is an improperly designed lower ball joint that is prone to failing prematurely. Luckily I do not think there have been any serious injuries yet but I am sure they are going to happen. Lexus should do the right thing and address this problem by replacing the defective ball joints with ones that are designed to last but they are choosing to ignore it. It may bite them in the end and they are aware of the problem. Sometimes companies have to bite the bullet and spend the movie to resolve things that they should.
#54
Maintenance Moderator
"prone to failing early"
sounds like someone isn't doing their maintenance inspections... Lexus specifies inspection intervals for those - its not like they fail all at once, they always get loose and have play prior to failing... these should be checked at standard intervals (every 30k? I think) and caught prior to failing...
GM has a huge issue with their 3.x liter V6 motors found in all of their FWD cars from 1995 to 2002 - they leak coolant from the intake manifold gaskets (evidence supports the theory that the OE gaskets aren't compatible with dexcool, but its not rock solid) Anyways, its like an $800 repair... No recalls there either...
#56
I'm not having a much on an issue with my 04 paint. I know the paint is now more brittle being that it's water based instead of solvent based but look at my 04. This vehicle has had 6 round trips from Milwaukee, WI to Cape Coral, FL (3,200 miles each) of freeway driving and I have no chips. I also drive the freeways around here in the winter when they are loaded with salt and I cringe when I hear the salt hitting the front of the car but so far the paint has stood up well. There is no clear bra or anything on this car. In one trip I was behind a gravel truck when his tailgate broke dropping a lot of golf ball sized gravel on the freeway right in front of me. These stones were bouncing off the front bumper and when I stopped to check for damage there was none. This is a Japan built RX if that makes any difference. So what does your car look like that prompts your complaints and where was it built?
#57
#58
I don't think so, this is not a simple maintenance issue. I have read about and know several people that this happend to with little to no warning and Lexus never informed them of getting them inspected nor did their mechanics and the car gave no warning signs either. Some of the failures were well before 90K miles. Lower ball joints are not supposed to fail before or anywhere near 100K miles unless the car is driven extremely hard and takes alot of abuse. Ball joints are generally supposed to last the life of the car, at least that is what all mechanics have said to me when I insisted they be checked. My family and I keep our cars well over 100K miles some closer to 200K miles and have never once had any kind of lower ball joint issue, it is not normal for these ball joints to be failing like they are and it is a poor design where they destroy the suspension in the GS when they do fail and can cause a serious accident.
#59
Lexus is well aware of their paint problems. Class action suit filed
http://www.protectingtheconsumer.com...t-problems.php
My name is on the complaint. Please see link and pass the word. I have a 1999 blazer with zero chips and better paint job. Theres a video on youtube showing a test between a Ford Taurus and an LS 460. The LS look like it went a 100,000 miles and the front end is destroyed while the Taurus looks great.
#60
Good bump of an old thread; that link has some good info. If you personally are having a problem, go for it, pursuit of perfection and all that.
But don't try to convince others or expect sympathy from people who aren't having an issue.
However it turns out, it'll make the lexus I buy in 2015 that much better.
