Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Clear Bra Waxing?
Old 06-22-06, 03:07 PM
tuanis
tuanis's Avatar
Default Clear Bra Waxing?
My apologies for the silly question. Im a newbie. IS 350, black, clear bra. So, when I wax my car do I wax the clear bra along with it?
Old 06-22-06, 03:41 PM
conekiller
conekiller's Avatar
yes - treat it like it's not even there
Old 06-22-06, 04:09 PM
Bengalfang
Bengalfang's Avatar
I would recommend that you put painters tape along the edge of the clear bra so you don't get wax underneath it. I got a bit under part of mine, so now there is a white line.....
Old 06-22-06, 05:10 PM
drck1000
drck1000's Avatar
I second the use of painters tape. I'll add to be VERY careful when claying around the edges as well. I used the blue Clay Magic clay and got too close to the clear bra edge and it was practically impossible to remove. I actually had the clear bra replaced for another reason, so no harm done in my case. Don't need blue crap stuck in the edges of the film
Old 06-22-06, 09:03 PM
nighthawk
nighthawk's Avatar
This is the MAJOR drawback to a clear bra....it makes it a pain to wax around it.....
Old 06-22-06, 10:23 PM
HarrierAWD
HarrierAWD's Avatar
Just use Q-tip to clear the wax at the seam. You must do it while the wax is still soft.
Old 06-23-06, 06:28 AM
CVsIS250
CVsIS250's Avatar
I have a clear bra and wax around it without any special treatment. I don't have any problems.
CV
Old 06-23-06, 09:39 PM
UAL
UAL's Avatar
I've had two clear bra installers and Premier told me to avoid the line when waxing while Aerotect did not. I've figured out that it is much easier by waxing to the seam and stopping. My best opinion is to get a custom bra installation because it would makeit much easier during detailing. I have my bra on my GS installed by Premier and my 650i by Aerotect, which did not align up that well on the hood. The bra is much more noticeable on my 650i when it's dirty because there's quite a bit more gap on one side than the other. I tried one detailer and he left a wax trail on my 650i and is very noticeable especially in the areas that are a bit away from the edge. On my GS done by Premier, it looks much better because they covered the entire hood and also covered the edges so that nothing shows over tiem from wear. Go with a pro that can wrap the edges. it makes it look much better since wax doesn't get trapped.
Old 08-08-07, 11:08 PM
ULTiMaX99
ULTiMaX99's Avatar
can you clay and polish a clear bra?
Old 08-09-07, 12:54 AM
SC3coupe
SC3coupe's Avatar
I clayed my 3M and put wax on it not sure about polish though, I think it's not a good idea. Just avoid the edges.... a little quick detailer and MF cloth should take out stuff that accidently scratched the edge.
Old 08-09-07, 03:57 AM
GS300Rich
GS300Rich's Avatar
great info here. I will try what HarrierAWD suggested
Old 08-09-07, 09:28 AM
ULTiMaX99
ULTiMaX99's Avatar
what happens if you polish the clearbra? will it turn cloudy since the polish is an abrasive?
Old 08-09-07, 10:07 AM
SC3coupe
SC3coupe's Avatar
The 3M clear bra is supposed to have a clear coat on it like the clear coat on the car (polyurethane)? But I just don't want to take any chances and I personally use a buffer to apply polish and don't want to abuse the clear bra since it's just a piece of sticker It's shiny enough for me.
Maybe test in a small area first
Oh my question would be would it be ok to put aerospace 303 on it... would it protect from yellowing in the long term or actually yellow it faster?
Old 08-09-07, 10:14 AM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
wow i didnt know that you could wax the bra too
Old 08-10-07, 06:13 AM
OutlawTita
OutlawTita's Avatar
I recommend treating the bra the same as your paint but as a soft, fragile paint. Another words use the least abrasive polish and pads. Also, when waxing or polishing work from the bra toward the paint instead of from the paint toward the bra......this helps prevent buildup on the small ridges of the bra and makes it much easier to clean what little buildup you do get.
Quick Reply: Clear Bra Waxing?
